[SOLVED] Waiting for openHAB to become ready ... failed
Good evening,
I am a very beginner who wants to install openhabian v1.5 (openHAB version 2.4.0) on a raspberry pi 4B. The first big issue was to install java which I was able to manage by following this solution ending up with the following java-version:
openjdk version "1.8.0_222"
OpenJDK Runtime Environment (Zulu8.40.0.178-CA-linux_aarch32hf) (build 1.8.0_222-b178)
OpenJDK Client VM (Zulu8.40.0.178-CA-linux_aarch32hf) (build 25.222-b178, mixed mode, Evaluation)
So far so good. But every try (three to four) to reboot the system ended up with the following mistake (log-file):
2019-10-29_21:07:46_CET [openHABian] Setting up Samba network shares... OK
2019-10-29_21:07:48_CET [openHABian] Installing the openHAB Log Viewer (frontail)... OK
2019-10-29_21:08:11_CET [openHABian] Adding an openHAB dashboard tile for 'frontail'... Replacing... OK
2019-10-29_21:08:11_CET [openHABian] Execution of 'openhabian-setup.sh unattended' completed.
2019-10-29_21:08:11_CET [openHABian] Waiting for openHAB to become ready...1..2..3..4..5..6..7..8..9..10..11..12..13..14..15..16..17..18..19..20..failed.
As a new user I am not allowed to upload a file, so I will post the whole file if necessary.
I am working on it for hours right now and I am very frustrated. It would be great, if you could help me with it.
Thank a lot in advance!
Regards
BrainPain
it’s me again. I solved the problem by upgrading openHAB testing:
sudo openhabian-config
point “40 openHAB related” => openHAB testing
After the installation I reboot the raspberry and everything went fine :slight_smile:
I am sorry for opening an own thread for it.
Thanks and see you soon
BrainPain
So you installed version 2.5 Milestone 4. You might want to go to the stable version once 2.5 is released toward the end of this year.
Thanks, I will keep it in mind.
