With great help of many topics on this forum, I managed to calculate the water consumption for:
Today so far
This week / month / year so far.
Please find code below.
rule "sumSince Water"
Item CountWater changed or Item Refresh received update
sendCommand(CountWaterDay, CountWater.sumSince(now.withTimeAtStartOfDay()))
sendCommand(CountWaterWeek, CountWater.sumSince(now.withTimeAtStartOfDay().withDayOfWeek(1)))
sendCommand(CountWaterMonth, CountWater.sumSince(now.withTimeAtStartOfDay().withDayOfMonth(1)))
sendCommand(CountWaterYear, CountWater.sumSince(now.withTimeAtStartOfDay().withDayOfYear(1)))
I am now looking to get the consumption from previous month.
Here I found a nice piece of code that would somehow fit in my case, but I am struggling to get it in a one-line rule. Is there anyone that can fit this in the sumSince(.....) format?
Don’t do that, then. There’s no advantage, and going step by step allows you to understand what you’re doing - especially in the future when you come back to a long forgotten rule.
These might help
// 1st day of last calendar month
val startDate = now.minusMonths(1).withDayOfMonth(1).withTimeAtStartOfDay
// last minute of last day of previous month
val stopDate = now.withDayOfMonth(1).withTimeAtStartOfDay.minusMinutes(1)
// its less windy than
// now.minusMonths(1).dayOfMonth().withMaximumValue.getDayOfMonth
Hi @rossko57, thanks again for your help!
I did not succeed to get it work yet, but that is because of my limited knowledge.
I tried to implement your suggestion as follows.
Added the declaration of the variables inside the rule.
Added the variables inside the sumSince part.
but not surprisingly the log tells me that “startDate” is not a valid part of the rule.
How can I tell the rule not simply looking to “startDate” but to the declaration that is behind?
2020-11-12 20:18:01.081 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'sumSince Water': 'startDate' is not a member of 'org.joda.time.DateTime'; line 18, column 56, length 18
Persistence service sumSince() works with one date/time parameter only. One.
It adds values from the target date to “now”.
You cannot use sumSince() to get a sum from date X to date Y.
You can use sumSince() to get a sum from date X to now.
You can use sumSince() to get a sum from date Y to now.
You can then subtract one from the other.
Whether that is any use depends on how your data is stored, but it should work for daily records.
val oldsum = CountWater.sumSince(startDate)
logInfo("test", "Sum since old date " + oldsum.toString)
Thanks @rossko57!
I understand your point.
My code now looks as follows and it works!
val start = CountWater.sumSince(startDate)
val stop = CountWater.sumSince(stopDate)
val prevMonth = start - stop
logInfo("test", "Sum since old date " + prevMonth.toString)
sendCommand(CountWaterPrevMonth, prevMonth)
I am getting an error in OH3, so replaced with this: val startDate = now.minusMonths(1).withDayOfMonth(1).withHour(0).withMinute(0).withSecond(0)
Is this correct?
Thanks.
