YES MATE!
TX is twinkling again!
But immediately in the log appears that:
2019-02-02 17:13:47.511 [ERROR] [t.wimpi.modbus.io.ModbusRTUTransport] - Last request: 01 01 00 00 00 0f 7c 0e
2019-02-02 17:13:47.516 [ERROR] [t.wimpi.modbus.io.ModbusRTUTransport] - failed to read: Error reading response (EOF)
2019-02-02 17:13:47.547 [ERROR] [pi.modbus.io.ModbusSerialTransaction] - execute try 1/1 error: I/O exception: IOException Error reading response (EOF). Request: net.wimpi.modbus.msg.ReadCoilsRequest@1846485 (unit id 1 & transaction 1). Serial parameters: SerialParameters@c8155f[portName=/dev/ttyS0,baudRate=9600,flowControlIn=none,flowControlOut=none,databits=8,stopbits=1,parity=none,encoding=rtu,echo=false,receiveTimeoutMillis=1500]
2019-02-02 17:13:47.553 [ERROR] [pi.modbus.io.ModbusSerialTransaction] - execute reached max tries 1, throwing last error: I/O exception: IOException Error reading response (EOF). Request: net.wimpi.modbus.msg.ReadCoilsRequest@1846485 (unit id 1 & transaction 1). Serial parameters: SerialParameters@c8155f[portName=/dev/ttyS0,baudRate=9600,flowControlIn=none,flowControlOut=none,databits=8,stopbits=1,parity=none,encoding=rtu,echo=false,receiveTimeoutMillis=1500]
2019-02-02 17:13:47.562 [WARN ] [rt.modbus.internal.ModbusManagerImpl] - Try 1 out of 3 failed when executing request (ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@148e63a[slaveId=1,functionCode=READ_COILS,start=0,length=15,maxTries=3]). Will try again soon. Error was I/O error, so reseting the connection. Error details: net.wimpi.modbus.ModbusIOException I/O exception: IOException Error reading response (EOF) [operation ID 6d5d93bc-45be-44ac-9976-7655c5b6197c]
2019-02-02 17:13:49.200 [ERROR] [t.wimpi.modbus.io.ModbusRTUTransport] - Last request: 01 01 00 00 00 0f 7c 0e
2019-02-02 17:13:49.203 [ERROR] [t.wimpi.modbus.io.ModbusRTUTransport] - failed to read: Error reading response (EOF)
2019-02-02 17:13:49.208 [ERROR] [pi.modbus.io.ModbusSerialTransaction] - execute try 1/1 error: I/O exception: IOException Error reading response (EOF). Request: net.wimpi.modbus.msg.ReadCoilsRequest@4455ce (unit id 1 & transaction 2). Serial parameters: SerialParameters@c8155f[portName=/dev/ttyS0,baudRate=9600,flowControlIn=none,flowControlOut=none,databits=8,stopbits=1,parity=none,encoding=rtu,echo=false,receiveTimeoutMillis=1500]
2019-02-02 17:13:49.211 [ERROR] [pi.modbus.io.ModbusSerialTransaction] - execute reached max tries 1, throwing last error: I/O exception: IOException Error reading response (EOF). Request: net.wimpi.modbus.msg.ReadCoilsRequest@4455ce (unit id 1 & transaction 2). Serial parameters: SerialParameters@c8155f[portName=/dev/ttyS0,baudRate=9600,flowControlIn=none,flowControlOut=none,databits=8,stopbits=1,parity=none,encoding=rtu,echo=false,receiveTimeoutMillis=1500]
2019-02-02 17:13:49.216 [WARN ] [rt.modbus.internal.ModbusManagerImpl] - Try 2 out of 3 failed when executing request (ModbusPollerThingHandlerImpl.ModbusPollerReadRequest@148e63a[slaveId=1,functionCode=READ_COILS,start=0,length=15,maxTries=3]). Will try again soon. Error was I/O error, so reseting the connection. Error details: net.wimpi.modbus.ModbusIOException I/O exception: IOException Error reading response (EOF) [operation ID 6d5d93bc-45be-44ac-9976-7655c5b6197c]
