Hello Folks,
Hopefully someone can give me a little help in here.
My current project is to connect our Westaflex Ventilation System with ModBus.
I have a Raspi with Openhab 2 running and a rs485 Hat and it’s connected to the rs485 from the Westaflex.
Iam also a little bit familiar with the Openhab.
But now it comes to where I need help. Westaflex is providing something at GitHub to connect the Ventilation System to the Openhab:
But how did I “manual” Binding, because in the List of Bindings there is Westaflex available.
thank you for your answer.
I did the Modbus Binding but now it´s getting difficult for me.
The RS485 Shield i use is this: https://www.hwhardsoft.de/2017/10/07/rs422-rs485-raspberry-pi-hat/
i hope is installed it right.
Can i Test the Shield with the console ?
And then i would kindly ask if you can give me a example in witch way i have to
add thing/item to read/write the Westaflex Modbus adresses ?
I don’t know how you even set the unit address on that. That manual suggest baud rate is 19200. It’s really going to help if you can find out what model you have.
Excellent.
Let’ start simple then. The docs show there are sixteen coils for various functions, addresses 0-15. Start address 0 , length 16
So add a poller Thing to your serial Thing for those.
At this stage, openHAB should be read polling your Westaflex. If there are twinkly lights for this, you should see them twinkle.
Most of the ‘coils’ seem to be alarm signals, so there won’t normally be anything much to see or any need to turn them on/off. coil 12 seems to be “Fans on”, so that would be a good one to add a data Thing for, to that poller.
Once you’ve got that data thing, you can add a Switch type Item, and link it to the modbus data channel.
Now you start guessing.
Might be something wrong with your poller settings, but you kept those secret.
More likely, something about establishing the modbus connection.
Confident your serial Thing is pointing to the RS485 hardware?
A/B wires swapped, using twisted pair? How long is the cable, do you need to arrange termination?
It’s easier to fault find this kind of problem using mbpoll or similar tools.
Ok, the wiring seems to be ok.
On the RS485 board the TX and RX LEDs not twinkle at any time.
I guess i did not configure it right…but I did everything in the manual:
I know nothing about setting up Pi serial, but that seems like a big clue this is where the problem lies. Working Poller should twinkle Tx light even with no cable connection.
Looks like it ought to come up on AMA0. I can’t help with this part.
HI there,
long time no hear cause i went out for a Business trip in the UK.
The Supplier of the RS485 Shield told me that to to to get the Shield running:
sudo raspi-config
'5 Interfacing Options' auswählen
'P6 Serial' auswählen
'Would you like a login shell to be accessible over serial?' --> NO
'Would you like the serial port hardware to be enabled?' --> YES
raspi-config close
Raspberry Pi reboot
now you can use the /dev/ttyS0
If this worked well i should see the TX light twinkelin somehow.
It does (YEAH). But after it try to read a adress with the Poll/Thing/item in my PaperUI
It stopps, and never worked again…
Make sure you have no westaflex files in addons.cfg or something like.
Configure just a serial thing and a poller thing.
Delete data things.
Disconnect wires to RS485.
close down openHAB
Perform the instructions for getting the card as ttyS0
These thing is driving me crazy…
I did a full wipe of SDcard and flashed it new with etchter.
But there so Errors If I login console:
2019-02-02_13:10:36_UTC [openHABian] Ensuring network connectivity… OK
2019-02-02_13:10:36_UTC [openHABian] Waiting for dpkg/apt to get ready… OK
2019-02-02_13:10:45_UTC [openHABian] Updating repositories and upgrading installed packages… FAILED
2019-02-02_13:10:51_UTC [openHABian] Initial setup exiting with an error!
Update:
I did a another flash of the SD card… now its working…
