Here you go - as you see I commented already a lot out in order to see if any of the blocks causes the exclamation mark --> do you if the ! should state an error or if it has a different meaning?
sitemap brunn label="Brunn" {
Frame label=Alarmanlage {
Switch item=varAlarmanlage
Group item=gAlarms
Frame label="Wohnungsklima" {
Text item=senTemp_WohnzimmerNA //valuecolor=[Last_Update=="Uninitialized"="#808080",>=25="#ffa500",>=19="#008000",<19="#0000ff"]
Text item=senHumidity_WohnzimmerNA //valuecolor=[Last_Update=="Uninitialized"="#808080",>=50="#ffa500", >=35="#008000",<35="#ffa500"]
Text item=senCO2_Wohnzimmer //valuecolor=[Last_Update=="Uninitialized"="#808080",>=1000="#ff0000",>=800="#ffa500",<800="#008000"]
Text item=setHeat_BadMode {
Setpoint item=setHeat_BadEco minValue=4.5 maxValue=30 step=0.5
Setpoint item=setHeat_BadComf minValue=4.5 maxValue=30 step=0.5
Switch item=setHeat_BadMode mappings=[1="Comfort",11="ECO"]
Text item=senTemp_HeatBad
Frame label="Sonos" {
Default item=varSonos_WohnzimmerStatus
Default item=plaSonos_Wohnzimmer
Slider item=dimSonos_WohnzimmerVol
Text item=varSonos_WohnzimmerTrack
Switch item=varSonos_WohnzimmerRadioInput mappings=[0="Ö3",1="Ö1",2="Kronehit"]
Frame label="Wetter Brunn" {
Text item=weaTemp_Brunn //valuecolor=[Last_Update=="Uninitialized"="#808080",>=25="#ffa500",>=15="#008000",<15="#0000ff"]
Text item=weaHumidity_Brunn
Text item=weaPressure_Brunn
Text item=weaTemp_Terrasse //valuecolor=[Last_Update=="Uninitialized"="#808080",>=25="#ffa500",>=15="#008000",<15="#0000ff"]
Frame label="Sonstige Infos" {
Group item=gSysinfo
Switch item=gLightsEG mappings=[OFF="Alle aus", ON="Alle an"]
Switch item=varLights_EGSzenen mappings=[0="Alle aus", 1="TV", 2="Smooth", 3="Alle an"]
Frame label="Leistung" {
Switch item=EumelPower_Chart_Period label="Zeitraum" mappings=[0="24h", 1="7D", 2="akt. Monat"]
Webview url="http://192.168.1.40:8080/static/charts/chartPT24h.html" height=15 visibility=[EumelPower_Chart_Period=="0", EumelPower_Chart_Period=="NULL"]
Webview url="http://192.168.1.40:8080/static/charts/chartPT7d.html" height=15 visibility=[EumelPower_Chart_Period=="1"]
Webview url="http://192.168.1.40:8080/static/charts/chartPT1M.html" height=15 visibility=[EumelPower_Chart_Period=="2"]
//height varies based on number of graphs and dimensions of them.
Frame label="Verbrauch" {
Switch item=EumelEnergy_Chart_Period label="Zeitraum" mappings=[0="24h", 1="7D", 2="akt. Monat"]
Webview url="http://192.168.1.40:8080/static/charts/chartEFATd.html" height=15 visibility=[EumelEnergy_Chart_Period=="0", EumelEnergy_Chart_Period=="NULL"]
Webview url="http://192.168.1.40:8080/static/charts/chartEFAT7d.html" height=15 visibility=[EumelEnergy_Chart_Period=="1"]
Webview url="http://192.168.1.40:8080/static/charts/chartEFAT1M.html" height=15 visibility=[EumelEnergy_Chart_Period=="2"]
/* Frame label="Leistungen"{
Switch item=EumelPower_Chart_Period label="Zeitraum" mappings=[0="H", 1="D", 2="W", 3="M", 4="Y"]
Chart item=gChartPowerEumel period=h refresh=1200 visibility=[EumelPower_Chart_Period==0]
Chart item=gChartPowerEumel period=D refresh=1800 visibility=[EumelPower_Chart_Period==1, EumelPower_Chart_Period=="NULL"]
Chart item=gChartPowerEumel period=W refresh=3600 visibility=[EumelPower_Chart_Period==2]
Chart item=gChartPowerEumel period=M refresh=3600 visibility=[EumelPower_Chart_Period==3]
Chart item=gChartPowerEumel period=Y refresh=3600 visibility=[EumelPower_Chart_Period==4]
Frame label="Verbrauch"{
Switch item=EumelEnergy_Chart_Period label="Zeitraum" mappings=[0="H", 1="D", 2="W", 3="M", 4="Y"]
Chart item=gChartEnergyEumel period=h refresh=1200 visibility=[EumelEnergy_Chart_Period==0]
Chart item=gChartEnergyEumel period=D refresh=1800 visibility=[EumelEnergy_Chart_Period==1, EumelEnergy_Chart_Period=="NULL"]
Chart item=gChartEnergyEumel period=W refresh=3600 visibility=[EumelEnergy_Chart_Period==2]
Chart item=gChartEnergyEumel period=M refresh=3600 visibility=[EumelEnergy_Chart_Period==3]
Chart item=gChartEnergyEumel period=Y refresh=3600 visibility=[EumelEnergy_Chart_Period==4]
Frame label="Temperatur"{
Switch item=EumelTemp_Chart_Period label="Zeitraum" mappings=[0="H", 1="D", 2="W", 3="M", 4="Y"]
Chart item=eumelTemp period=h refresh=1200 visibility=[EumelTemp_Chart_Period==0]
Chart item=eumelTemp period=D refresh=1800 visibility=[EumelTemp_Chart_Period==1, EumelTemp_Chart_Period=="NULL"]
Chart item=eumelTemp period=W refresh=3600 visibility=[EumelTemp_Chart_Period==2]
Chart item=eumelTemp period=M refresh=3600 visibility=[EumelTemp_Chart_Period==3]
Chart item=eumelTemp period=Y refresh=3600 visibility=[EumelTemp_Chart_Period==4]
Frame label="alle Steuerungen" {
Group item=gAll
