Hi everybody.
OpenHab 2.3 on Raspberry 3 with openhabian-config 1.4
I am using mysql as a persistence service.
assuming the value of an item hasn’t changed, should the following create a new entry in the table for the item?
item:
Number IrrigationRaisedBedMoistureMin "min. Bodenfeuchte Hochbeet [%d %%]" <water> (gGardenIrrigation, gPersistence)
Persistence:
gPersistence* : strategy = everyChange, restoreOnStartup
Part of a rule that gets regularly executed
IrrigationRaisedBedMoistureMin.sendCommand(IrrigationRaisedBedMoistureMin.state as DecimalType)
For me everytime the rule gets triggered, there isn’t an update in the persistence service. So I think that the persistence only stores new data when an item is updated and in addition the state of the item also has changed. But what I want to acheive is getting a new data set in the table if the item even if the state value has not changed
I see in the log that the item gets updated with the new state;
2018-07-12 22:34:42.719 [ome.event.ItemCommandEvent] - Item 'IrrigationRaisedBedMoistureMin' received command 40
Am i doing something wrong here?
