Platform information:
Hardware: synology DS218play
OS: DSM 6.2.2-24922 Update 2
ava Runtime Environment: build 1.8.0_251-b08
openHAB version: openHAB-2.5.2.000
xiaomi gateway version: lumi.gateway.v3 v1.4.1_175
first time i install openhab in my synology dsm is ok
i can read and write any value from xiamoi gateway
after that, i want install Blynk server in my synology
but it have some problem with port 8080
so i uninstall the openhab
when i install the openhab again and setup my binding for xiaomi
i open can get the value from gateway (when i turn on/off with APP, it can show it)
but i cant control gateway with openhab any more
i try reinstall so many time…
i have already read this doc
My gateway shows up in openHAB and I have added all devices, but I don’t get any value updates:
- Most likely your machine is not receiving multicast messages
- Check your network config:
- Routers often block multicast - enable it
- Make sure the gateway and the machine are in the same subnet
- Try to connect your machine via Ethernet instead of Wifi
- Make sure you don’t have any firewall rules blocking multicast
i have checked the gateway port 9898 is open
how can i fix it?
thank a lot!!
