Hi.
miio:basic:0530A86D “ZhiRui bedside Lamp” [host=“192.168.1.12”, token=“xxx”]
Hi.
Is it working? I still have problems with the bedside lamp…
Hi Paulo,
I was able connect it using binding:
But I didnt sent author all commands to include it in binding so most of the stuff I have to send over command channel
I found some description, but can not control stuffs like Disco light or RGB color.
I can control:
turn it on/of with set_power[“off”] (on/off) change briteness wtih set_bright[10] (1-100) and white temp with set_cct[50] (1-100). Also useless toggle and night mode with go_night. And last apply_fixed_scene[1] (1-5)
Can someone send the debug log of the get_prop["pow", "sta", "bri", "rgb", "cct", "snm", "spr", "spt", "wke", "bl", "ms", "mb", "wkp"] to know what are the responses to each.
I would expect the basic functions like on/off to work. The database has about 8 channels
If that is not the case let me know. We can see how to get them going.
For the more advanced stuff like Disco light you probably need to get the commands via logging with wireshark, or search the internet if someone has the correct command for it. (you can’t get it by decompiling the apk, as these scenes are pulled from the cloud)
These are the results, no? Sorry Marcel I send nothing yet, but still not complete. only working are commans in preview posts …
Sending cmd get_prop with params ['pow', 'sta', 'bri', 'rgb', 'cct', 'snm', 'spr', 'spt', 'wke', 'bl', 'ms', 'mb', 'wkp'] ['off', 0, 1, 16741971, 1, 0, 0, 15, 0, 1, 1, 1, [0, 24, 0]]
Just didt get for what are params for, when you send only methods …
I can send over control channel:
turn it on/of with set_power[“off”] (on/off) change briteness wtih set_bright[10] (1-100) and white temp with set_cct[50] (1-100). Also useless toggle and night mode with go_night . And last apply_fixed_scene[1] (1-5)
set_rgb[6545456] not working for me (number is hexa color converted into decimal) - #8FB8D7 – 9418967, lamp answer OK, but nothing change
I tried to do these commands, please see my post for information:
any help would be appreciated!
But Mine is Xiaomi Philips Zhirui Bedside Lamp, not complete same …
Yeelight have nice PDF docu:
I am very new to all this stuff. So far I managed to toggle on and off my Xiaomi Yeelight Bedside Lamp. Now I would like to be able to set the sunrise/wakeuplight scene. It is working with the yeelight app, but how can I achieve this with openhab?
How can I log the command send from the app using wireshark?
I tryed use wireshark but all i see is some UDP crypted tunnel traffic between lamp and internet/app and sadly i see no commands or GET requests ![]()
