[SOLVED] Yahoo Weather Binding - OFFLINE - COMMUNICATION_ERROR The Yahoo Weather API is not available for the location
@andy31
System			         Linux				            Linux				            Windows
File Location		     Repository Installation		Manual Installation
openHAB application	     /usr/share/openhab2		    /opt/openhab2			    C:\openHAB2\runtime
Additional add-on files	 /usr/share/openhab2/addons	    /opt/openhab2/addons		C:\openHAB2\addons
Site configuration	     /etc/openhab2			        /opt/openhab2/conf		    C:\openHAB2\conf
Log files		         /var/log/openhab2		        /opt/openhab2/userdata/logs	C:\openHAB2\userdata\logs
Userdata like rrd4j db 	 /var/lib/openhab2	            /opt/openhab2/userdata		C:\openHAB2\userdata
Backups folder		     /var/lib/openhab2/backups	    /opt/openhab2/backups		(not preconfigured)
Service configuration	 /etc/default/openhab2		    (not preconfigured)		    C:\openHAB2\userdata\etc
I don’t know your samba shares. Above paths are “local paths” on your raspi.
Learning something new everyday. I got it under this location
After opening weather file I can see completely different configs (collection of some settings I tried earlier) which definitely does not match with weather.cfg file I shared earlier.
apikey.OpenWeatherMap="deXXXXXXXXXXXXXXXXXXX"
location.<locationId1>.units="SI"
location.WR.language="en"
location.WR.latitude="47.8011"
location.WR.longitude="13.0448"
location.WR.name="City"
location.WR.provider="OpenWeatherMap"
location.WR.updateInterval="10"
location.myhome.language="en"
location.myhome.latitude="41.576"
location.myhome.longitude="21.570"
location.myhome.name="London,\ GB"
location.myhome.provider="OpenWeatherMap"
location.myhome.units="SI"
location.myhome.updateInterval="15"
location.myhomes.language="en"
location.myhomes.latitude="48.574"
location.myhomes.longitude="14.580"
location.myhomes.name="myhomes"
location.myhomes.provider="OpenWeatherMap"
location.myhomes.updateInterval="1"
service.pid="org.openhab.weather"
Should I correct the content of this file or should this be removed ?
@andy31
You could delete the file weather.config and restart openhab service.
It works now :grinning: Many thanks.
Now just need to add some additional items to expand on my weather widget.
Will set interval frequency to 60 as it should be fast enough.
@andy31
Tick the solved mark please. Others maybe find this also helpful. Thanks.
Hi Everyone!
I’ve just started tinkering with weather widgets in OH3.
That page is moved, now you should write a request e-mail to get free API access (for 1 year, no automatic renewal):
API for non-commercial uses
Thanks for info @kajarit
