I have upgraded from 2.3 to 2.4 M6 and have an option of node_1 which some of my older devices have, or controller. Which one should I use? I have a newly added device that doesnt seem to report back to the UI the state from manual switch changed - not sure if perhaps it should be node_1 but I dont have that option on this device
I think that node_1
and Controller
are the same thing. You can select multiple nodes.
Here is an example from one of my nodes (FGMS001 Motion Sensor):
Note that not all Zwave devices support multiple nodes for the association group.
So standardising on Controller should be fine?
Should be. That is what I use.
