Hey there. I’m completely new to this stuff, and have been doing linux things only for a few weeks now.
What I have done is: Installed Raspbian on a Raspberry Pi Model B(the old one, it was lying around) fitted with a zwave.me raZberry module. Then I installed OpenHAB2, and it seems to work fine. I can access the paper ui and add bindings and things and so on.
Next I installed the Z-Wave Binding and added a thing “Z-Wave Serial Controller” and now this shows me an error: “zwave.thingstate.serial_notfound”
What I already did is:
switched off the serial console of the pi in raspi-config
chmod 777 /dev/ttyAMA0
usermod -a -G dialout openhab
Then rebooted aaaand…nothing changed. Any suggestions? Thank you in advance…
Thanks George,
I already double checked that. /dev/ttyAMA0 is the serial port located on the gpio header of the raspberry pi, and that is where the module is sitting. I did the following:
Another thing I found in the documentation of the serial binding:
If you are using non standard serial ports you have to adapt start.sh to have the serial port included. The java command line should then include the following parameters:
-Dgnu.io.rxtx.SerialPorts=/dev/ttyAMA0
Unfortunately, I can’t find a start.sh
I got Openhab2 to start upon booting with the command from the OpenHAB2 Tutorial:
sudo update-rc.d openhab2 defaults
Finally, the thing says it is online! Thank you very much for your super fast help. Now I am waiting for my first wall plug to arrive. I have a last question regarding the topic: Where could i have found that information by myself? I don’t want to bother people with my beginner’S questions all the time…
