RPi 4
OH2 2.5.0
Z-Wave Binding version: Latest as of 2 weeks ago
I have multiple dimmer devices that are being sent commands to turn them off (upon a rule sendCommand), then immediately a message comes out to set them to some value near 50 out of the clear blue. And the switch indicator in HabMIN bounces from Off to On.
As an example, I have a GoControl bulb triggered by a rule that sends a command to the light. Please let me know why this is happening.
(p.s., I don’t know the right way to post log information, pls let me know if I’m doing it wrong. I’m also uploading the file in case that is the right thing to do)
2020-01-31 05:54:38.865 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 26: Command received zwave:device:b6e7c13d:node26:switch_dimmer --> OFF [OnOffType]
2020-01-31 05:54:38.879 [DEBUG] [ss.ZWaveMultiLevelSwitchCommandClass] - NODE 26: Creating new message for command SWITCH_MULTILEVEL_SET
2020-01-31 05:54:38.887 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 26: SECURITY not supported
2020-01-31 05:54:38.889 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 26: Command Class COMMAND_CLASS_SWITCH_MULTILEVEL is NOT required to be secured
2020-01-31 05:54:38.891 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 26: Adding to device queue
2020-01-31 05:54:38.894 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 26: Added 1593 to queue - size 11
2020-01-31 05:54:38.902 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 26: Sending REQUEST Message = 01 0A 00 13 1A 03 26 01 00 25 41 BC
2020-01-31 05:54:38.910 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 26: Polling initialised at 86400 seconds - start in 1500 milliseconds.
2020-01-31 05:54:38.962 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 26: sentData successfully placed on stack.
2020-01-31 05:54:38.967 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 26: TID 1593: Transaction not completed
2020-01-31 05:54:38.985 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 26: SendData Request. CallBack ID = 65, Status = Transmission complete and ACK received(0)
2020-01-31 05:54:38.988 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 26: resetResendCount initComplete=true isDead=false
2020-01-31 05:54:38.992 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 26: Response processed after 84ms
2020-01-31 05:54:38.993 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 26: TID 1593: Transaction completed
2020-01-31 05:54:38.995 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 26: notifyTransactionResponse TID:1593 DONE
2020-01-31 05:54:38.997 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 26: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2020-01-31 05:54:40.410 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 26: Polling...
2020-01-31 05:54:40.413 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 26: Polling zwave:device:b6e7c13d:node26:switch_dimmer
2020-01-31 05:54:40.416 [DEBUG] [erter.ZWaveMultiLevelSwitchConverter] - NODE 26: Generating poll message for COMMAND_CLASS_SWITCH_MULTILEVEL, endpoint 0
2020-01-31 05:54:40.419 [DEBUG] [ss.ZWaveMultiLevelSwitchCommandClass] - NODE 26: Creating new message for command SWITCH_MULTILEVEL_GET
2020-01-31 05:54:40.423 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 26: SECURITY not supported
2020-01-31 05:54:40.427 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 26: Command Class COMMAND_CLASS_SWITCH_MULTILEVEL is NOT required to be secured
2020-01-31 05:54:40.430 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 26: Polling skipped for zwave:device:b6e7c13d:node26:switch_dimmer on COMMAND_CLASS_BASIC
2020-01-31 05:54:40.435 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 26: Adding to device queue
2020-01-31 05:54:40.438 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 26: Added 1594 to queue - size 11
2020-01-31 05:54:40.453 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 26: Sending REQUEST Message = 01 09 00 13 1A 02 26 02 25 42 BE
2020-01-31 05:54:40.495 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 26: sentData successfully placed on stack.
2020-01-31 05:54:40.500 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 26: TID 1594: Transaction not completed
2020-01-31 05:54:40.520 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 26: SendData Request. CallBack ID = 66, Status = Transmission complete and ACK received(0)
2020-01-31 05:54:40.523 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 26: resetResendCount initComplete=true isDead=false
2020-01-31 05:54:40.527 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 26: TID 1594: Transaction not completed
2020-01-31 05:54:40.535 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 26: Application Command Request (ALIVE:DONE)
2020-01-31 05:54:40.537 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 26: resetResendCount initComplete=true isDead=false
2020-01-31 05:54:40.540 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 26: Incoming command class COMMAND_CLASS_SWITCH_MULTILEVEL, endpoint 0
2020-01-31 05:54:40.543 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 26: SECURITY not supported
2020-01-31 05:54:40.545 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 26: Received COMMAND_CLASS_SWITCH_MULTILEVEL V1 SWITCH_MULTILEVEL_REPORT
2020-01-31 05:54:40.548 [DEBUG] [ss.ZWaveMultiLevelSwitchCommandClass] - NODE 26: Switch Multi Level report, value = 48
2020-01-31 05:54:40.550 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 26: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2020-01-31 05:54:40.553 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 26: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_SWITCH_MULTILEVEL, value=48
2020-01-31 05:54:40.556 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 26: Updating channel state zwave:device:b6e7c13d:node26:switch_dimmer to 48 [PercentType]
2020-01-31 05:54:40.560 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 26: Commands processed 1.
2020-01-31 05:54:40.578 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 26: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@7adee5.
2020-01-31 05:54:40.585 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 26: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@7adee5.
2020-01-31 05:54:40.588 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 26: notifyTransactionResponse TID:1594 DONE
2020-01-31 05:54:40.591 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 26: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent[DimmerOffToOnPercentage.txt|attachment](upload://iCTi8SKztTP1ZwQC9pTw2f0nQ4Q.txt) (6.0 KB)
