Running: OH 2.4-Stable
RPi 3 B+
Aeotec Z-Wave stick
openjdk version “1.8.0_152”
I have a rule to turn my garage lights (3) on at dusk. When I came home last night they were not on. HabMin does not show them as not responding so I k now (think?) they are powered.
I can turn them on via the PaperUI and it thinks they are on, but the lights do not actually come on.
The rule has been working just fine for months up until this.
Other rules (triggered and manual) still run fine.
I turned on DEBUG mode and tried to turn on my Garage Lights Group and here is what showed:
2018-12-30 12:32:01.327 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Command received zwave:device:512:node2:switch_dimmer --> ON [OnOffType]
2018-12-30 12:32:01.330 [DEBUG] [ss.ZWaveMultiLevelSwitchCommandClass] - NODE 2: Creating new message for command SWITCH_MULTILEVEL_SET
2018-12-30 12:32:01.334 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: SECURITY not supported
2018-12-30 12:32:01.336 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: Command Class COMMAND_CLASS_SWITCH_MULTILEVEL is NOT required to be secured
2018-12-30 12:32:01.338 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Adding to device queue
2018-12-30 12:32:01.341 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Added 8207 to queue - size 3
2018-12-30 12:32:01.352 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 2: Sending REQUEST Message = 01 0A 00 13 02 03 26 01 FF 25 2E 34
2018-12-30 12:32:01.377 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Polling intialised at 86400 seconds - start in 1500 milliseconds.
2018-12-30 12:32:01.431 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 2: sentData successfully placed on stack.
2018-12-30 12:32:01.437 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: TID 8207: Transaction not completed
2018-12-30 12:32:02.878 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Polling...
2018-12-30 12:32:02.882 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Polling zwave:device:512:node2:switch_dimmer
2018-12-30 12:32:02.885 [DEBUG] [erter.ZWaveMultiLevelSwitchConverter] - NODE 2: Generating poll message for COMMAND_CLASS_SWITCH_MULTILEVEL, endpoint 0
2018-12-30 12:32:02.887 [DEBUG] [ss.ZWaveMultiLevelSwitchCommandClass] - NODE 2: Creating new message for command SWITCH_MULTILEVEL_GET
2018-12-30 12:32:02.890 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: SECURITY not supported
2018-12-30 12:32:02.893 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: Command Class COMMAND_CLASS_SWITCH_MULTILEVEL is NOT required to be secured
2018-12-30 12:32:02.896 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Polling skipped for zwave:device:512:node2:switch_dimmer on COMMAND_CLASS_BASIC
2018-12-30 12:32:02.900 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Adding to device queue
2018-12-30 12:32:02.903 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Added 8210 to queue - size 5
2018-12-30 12:32:06.438 [DEBUG] [sactionManager$ZWaveTransactionTimer] - NODE 2: TID 8207: Timeout at state WAIT_REQUEST. 3 retries remaining.
2018-12-30 12:32:06.462 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 03 00 16 EA
2018-12-30 12:32:08.649 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 2: SendData Request. CallBack ID = 46, Status = Transmission complete, no ACK received(1)
2018-12-30 12:32:08.658 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2018-12-30 12:32:08.662 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: CANCEL while sending message. Requeueing - 2 attempts left!
2018-12-30 12:32:08.668 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Adding to device queue
2018-12-30 12:32:08.670 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Added 8207 to queue - size 8
2018-12-30 12:32:08.682 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 2: Sending REQUEST Message = 01 0A 00 13 02 03 26 01 FF 25 2F 35
2018-12-30 12:32:08.697 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: TID 8207: Transaction not completed
2018-12-30 12:32:08.735 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 2: sentData successfully placed on stack.
2018-12-30 12:32:08.740 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: TID 8207: Transaction not completed
2018-12-30 12:32:13.740 [DEBUG] [sactionManager$ZWaveTransactionTimer] - NODE 2: TID 8207: Timeout at state WAIT_REQUEST. 2 retries remaining.
2018-12-30 12:32:13.750 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 03 00 16 EA
Here is the definition of my lights and groups:
Group allLights
Group outsideLights
Group:Dimmer garageLights
Dimmer sGarageLights "Garage Lights" <switch> [ "Lighting" ] // For Alexa
Dimmer sOutdoorLights "Outdoor Lights" <switch> [ "Lighting" ] // For Alexa
Dimmer sDenLights "Den Lights" <switch> [ "Lighting" ] // For Alexa
Switch Light_Garage_Side "Garage Side" <light> (outsideLights, garageLights, allLights)
channel="zwave:device:512:node2:switch_dimmer"
Switch Light_Garage_Right "Garage Right" <light> (outsideLights, garageLights, allLights)
channel="zwave:device:512:node15:switch_dimmer"
Switch Light_Garage_Left "Garage Left" <light> (outsideLights, garageLights, allLights)
channel="zwave:device:512:node16:switch_dimmer"
Since I cannot manually trigger the rule, I don’t think this is a problem with the Astro binding.
Anyone ever seen this kind of behavior?
Happy New year!
=C=
