[SOLVED] Z-Wave thing appears twice after re-discovery (Devolo MT2650)
Dear all,
I tried to setup my new Z-Wave thermostat, see here:
As I couldn’t find out how to solve this, I decided to remove the device (it was node 3) and to search again.
Now I found two devices (node 3 and 4) where both are not responding and the thermometer display blinks upon press of a button. Resetting the device, deleting the items, clearing the cache, rebooting OH leads to the same results: I always find two devices again.
zw
Any idea someone? Can I force the controller to forget the two devices (without controller hard reset) and to find the thermostat as node 3 again?
Z-Wave is really strange :frowning:
What do you mean by “remove”? Did you exclude it from the zwave network?
As for getting rid of “ghost” nodes from the controller, I use the Zensys tool, and follow the procedure outlined here. I find the Zensys tool to work more consistently than any other tool.
I am not sure: I set the “exclude device” switch in the thing properties and confirmed with the upper left “check confirmation button”.
Then I deleted the thing and the item.
But I am unsure whether this properly worked.
To properly exclude a device, you put the controller into exclude mode, then do “something” on the device. The “something” is a button press or series of button presses as described in the device user manual.
If you’re using Paper UI to manage your zwave devices, I would suggest you use the HABmin UI instead.
Do I only set the switch, or do I have to confirm with the upper left “check confirmation button”?
Sorry, but I don’t know what this is. In HABmin, when the Serial Controller thing is selected, it looks like this on the Tools menu (after selecting Show Advanced Settings.
html%23%3Athi
I mean the one in PaperUI
I don’t use Paper UI to manage my zwave devices, so I don’t really know.
Thanks. I’ll give it a try tonight :wink:
Ok, I did a proper hard reset. That killed all other devices as well, but at least the base is solid now. I included the devices again which took me some hours.
Now I am back at the beginning of my journey:
Can anyone help?
