- Platform information:
- RPi 3b, OH 2.5M4, cc2531 with zigbee2mqtt
I’ve got a Aqara double key wireless wall switch paired to zigbee2mqtt. It all works fine, the switch is publishing to mqqt like a charme, but the rule won’t be triggered if i press the same button twice.
e.g. i turn on the kitchen light with a right click and i want to turn it off with another right click again.
The switch sends the payload
{"linkquality":89,"battery":100,"voltage":3055,"click":"right"}
everytime i press the button, but my rule only triggers on change, so nothing happens after pressing the same button again.
I tried everything i found in the forum, Channel triggered, on received command/update …
My Thing
Thing mqtt:topic:doubleSwitchKitchen "doubleSwitchKitchen" (mqtt:broker:mosquitto) {
Channels:
Type string : click "Click" [ stateTopic="zigbee2mqtt/DoubleSwitchKitchen", transformationPattern="JSONPATH:$.click", trigger=true]
Type number : voltage "Voltage" [ stateTopic="zigbee2mqtt/DoubleSwitchKitchen", transformationPattern="JSONPATH:$.voltage"]
Type number : battery "Battery" [ stateTopic="zigbee2mqtt/DoubleSwitchKitchen", transformationPattern="JSONPATH:$.battery"]
My Items
String DoubleSwitchKitchenClick "Click" {channel="mqtt:topic:doubleSwitchKitchen:click"}
Number DoubleSwitchKitchenVoltage "Voltage" {channel="mqtt:topic:doubleSwitchKitchen:voltage"}
Number DoubleSwitchKitchenBattery "Battery" {channel="mqtt:topic:doubleSwitchKitchen:battery"}
RULES
rule "rule name"
when Channel "mqtt:topic:doubleSwitchKitchen:click" triggered
logInfo("Switch", "Channel triggered")
rule "React on Change"
Item DoubleSwitchKitchenClick changed
logInfo("Switch", "Item DoubleSwitchKitchenClick changed to "+ DoubleSwitchKitchenClick.state)
The second rules is only triggering if a pressed another button before…
The first one never triggers.
Does anyone have an idea how i can solve this problem?
Thank you in advance
