i’ve got a new smoke detector . Unfortunately it’s not in the zwave database, yet.
It looks similar to this one, which is in the database:
http://www.heimantech.com/product/96.html
I attached the created XML fille.node4.xml (7.6 KB)
Can someone help?
sihui
(SiHui)
February 23, 2018, 7:15am
#2
somehow i can’t receive an event in openhab when the alarm is triggered from the smoke detector. Battery status is shown normally.
Maybe i’m missing something?
My configuration:
Items:
Switch
Binary_sensor_Flur
“Binary Sensor”
(gFlur)
{channel=“zwave:device:9bc174e5:node4:sensor_binary”}
Switch
Rauchalarm_Flur
“Rauchalarm: [%s]”
(gFlur)
{ channel=“zwave:device:9bc174e5:node4:alarm_smoke” }
Number
Smoke_Detector_Bat_Flur
“Rauchmelder Flur Batterie: [%d %%]”
(gFlur,gBatterie)
{ channel=“zwave:device:9bc174e5:node4:battery-level” }
Rule:
rule Feueralarm
Item Rauchmelder_Flur received command ON
sendCommand(Rollladen_Kinderzimmer, UP)
sendMail("my@emaill.de", "Feueralarm", "Rauchmelder ausgelöst")
sendTelegram("bot1", "!!! Rauchmelder ausgelöst !!!")
Debug log while alarm is triggered manually:
2018-07-03 14:22:13.428 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 4: Transaction not completed: node address inconsistent. lastSent=4, incoming=255
2018-07-03 14:31:34.069 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 08 00 04 10 04 02 94 07 76
2018-07-03 14:31:34.088 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2018-07-03 14:31:34.107 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 08 00 04 10 04 02 94 07 76
2018-07-03 14:31:34.124 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 08 00 04 10 04 02 94 07 76
2018-07-03 14:31:34.137 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=10 04 02 94 07
2018-07-03 14:31:34.148 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 4: Application Command Request (ALIVE:DONE)
2018-07-03 14:31:34.157 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 4: Starting initialisation from DONE
2018-07-03 14:31:34.169 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@133f585 already registered
2018-07-03 14:31:34.179 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 4: Incoming command class SIMPLE_AV_CONTROL
2018-07-03 14:31:34.190 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 4: Command class SIMPLE_AV_CONTROL not found, trying to add it.
2018-07-03 14:31:34.209 [WARN ] [tocol.commandclass.ZWaveCommandClass] - NODE 4: Unsupported command class SIMPLE_AV_CONTROL
2018-07-03 14:31:34.255 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 4: Unsupported zwave command class SIMPLE_AV_CONTROL (0x94)
sihui
(SiHui)
August 22, 2018, 5:46am
#4
You don’t have your item defined.
