EDIT: Solution was a firmware update from 1.0 to 2.02
I have a Zooz Zen26 Zwave switch, it is a simply on/off switch. It is added to OpenHAB via the PaperUI as a “Thing” and I have assigned an item (a simple switch) to it’s switch channel.
When I toggle the switch Off → On, it updates in OpenHAB (on the habpanel and in the control secion) and if I toggle the switch On → Off it does the same. So control physically from the switch works fine.
Where things go to hell in a handbasket it when I go to control the switch from HapPanel or the control section in the PaperUI. If I toggle it from Off → On, it works just fine (every time, without fail), but when I toggle it from On → Off, it changes, but then openHAB immediately turns it back on (this happens consistently), though the switch remains in off mode (I have to physically toggle it on, then off to sync it back up).
Here are the relevant lines from the events.log file.
Toggling the switch physically.
2020-02-05 16:13:30.951 [vent.ItemStateChangedEvent] - MasterBedroom_Light_Zooz changed from OFF to ON
2020-02-05 16:13:30.957 [GroupItemStateChangedEvent] - gLight changed from OFF to ON through MasterBedroom_Light_Zooz
2020-02-05 16:13:33.448 [vent.ItemStateChangedEvent] - MasterBedroom_Light_Zooz changed from ON to OFF
2020-02-05 16:13:33.454 [GroupItemStateChangedEvent] - gLight changed from ON to OFF through MasterBedroom_Light_Zooz
And here it is from the habPanel and/or the control section in the PaperUI
Off to On:
2020-02-05 16:15:11.900 [ome.event.ItemCommandEvent] - Item 'MasterBedroom_Light_Zooz' received command ON
2020-02-05 16:15:11.925 [vent.ItemStateChangedEvent] - MasterBedroom_Light_Zooz changed from OFF to ON
2020-02-05 16:15:11.932 [GroupItemStateChangedEvent] - gLight changed from OFF to ON through MasterBedroom_Light_Zooz
On to Off (the line break is where openHab reverts the state).
2020-02-05 16:15:22.821 [ome.event.ItemCommandEvent] - Item 'MasterBedroom_Light_Zooz' received command OFF
2020-02-05 16:15:22.844 [GroupItemStateChangedEvent] - gLight changed from ON to OFF through MasterBedroom_Light_Zooz
2020-02-05 16:15:22.847 [vent.ItemStateChangedEvent] - MasterBedroom_Light_Zooz changed from ON to OFF
2020-02-05 16:15:25.931 [vent.ItemStateChangedEvent] - MasterBedroom_Light_Zooz changed from OFF to ON
2020-02-05 16:15:25.937 [GroupItemStateChangedEvent] - gLight changed from OFF to ON through MasterBedroom_Light_Zooz
I have no idea why this is happening, the suggestion is that it may have something do with the polling after the command has been sent, which is currently set to the default of “1500” and I did try some other valued (3000 and 6000) but that made no difference.
I have no idea where to go from here, or even where to look or what to change to try and diagnose this, so any help will be greatly appreciated.
Oh, and for the record:
Openhabian on a Raspberry Pi, everything configured via the PaperUI. The Zwave stick plugged into the Pi is across the room from the switch, which is sitting on my desk, so interference is very unlikely. And gLight is the item group the switch item has been placed in.
