[SOLVED] ZW3004 Honeywell Dimmer Switch Unrecognized
If you just want to update the binding, then I think you can use the script in the post below -:
Otherwise, the easiest way to keep on top of changes (but there’s obviously more risk) is to run your system on the snapshot branch. Exactly how you do this will depend on what your install is, but it should be covered in the docs.
