(Note I cannot add additional tags because I get a Internal server error then, but they are zwave, bindings, aeotec)
Openhab 2.5.1 from Qnap Club
QNAP TS-453 Pro (x86_64)
I had my Zwave and Zigbee devices on a Smartthings V3 hub which worked well but I want to process local and not cloud. So I got a Zigbee USB Stick, working great, and a Aeotec Zwave Stick Gen5.
I installed the Z-wave binding, and installed the stick as a serial controller. Works fine, device online.
I unplug my Smartthings Hub, factory reset my devices and put them in pairing mode (Fibaro Motion detector and Aeotec Trisensor).
They get recognized straight away and I can add them as things with all the expected channels.
They get an online status in the PaperUI Things:
And then…nothing happens. I try to trigger the motion sensor, try to read values, …nothing.
Both motion sensors will light up when motion is detected normally (on my Smartthings they did), and now not even that. Not only do they not communicate but they don’t seem to work even.
I put the logging to debug and observe…nothing again ![]()
I see all the messages flying through when pairing is ongoing, it all seems normal. And as you can see, 5 minutes of nothing. Total silence.
After that time, I press the action button to wake up the device and immediately logging occurs again. If I press the button to check network status, it gives the response it is connected.
I tried to pair the devices in inclusion mode (take stick to device and pair it there, then plug again and it shows up in Inbox but as an unknown device), or serial mode (plugged in and Openhab search).
Also tried the things from other topics where Fibaro Motion Detectors were not working but nothing.
Serial controller set up with no security, and network wide inclusion mode.
What is going on here ?
Log extract showing 1 device discovered, paired (23:20), and then communication when action button pressed (23:26 and again 23:30). Inbetween tried to trigger device all the time without result (and started to create some rules)
2020-03-17 23:20:22.750 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:55f456ae:node2.
2020-03-17 23:20:22.751 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Checking zwave:nietech_nzw96_00_000
2020-03-17 23:20:22.752 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Checking zwave:nietech_zw31_00_000
---------------- Plenty of lines like this removed to fit max size of topic ----------------
2020-03-17 23:20:22.924 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Handler disposed. Unregistering listener.
2020-03-17 23:20:23.035 [DEBUG] [al.protocol.ZWaveInclusionController] - ZWave inclusion controller finalised
2020-03-17 23:20:23.141 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - Initializing ZWave thing handler zwave:device:55f456ae:node2.
2020-03-17 23:20:23.144 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Controller status changed to ONLINE.
2020-03-17 23:20:23.144 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Controller is ONLINE. Starting device initialisation.
2020-03-17 23:20:23.148 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Updating node properties.
2020-03-17 23:20:23.154 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Updating node properties. MAN=881
2020-03-17 23:20:23.155 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Updating node properties. MAN=881. SET. Was 881
2020-03-17 23:20:23.158 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Properties synchronised
2020-03-17 23:20:23.163 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Configuration synchronised
2020-03-17 23:20:23.180 [DEBUG] [ve.internal.protocol.ZWaveController] - Event listener added.
2020-03-17 23:20:23.181 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Initialising Thing Node...
2020-03-17 23:20:23.223 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Initialising cmd channel zwave:device:55f456ae:node2:sensor_temperature for QuantityType
2020-03-17 23:20:23.224 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Initialising state channel zwave:device:55f456ae:node2:sensor_temperature for QuantityType
2020-03-17 23:20:23.225 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Initialising cmd channel zwave:device:55f456ae:node2:sensor_luminance for DecimalType
2020-03-17 23:20:23.225 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Initialising state channel zwave:device:55f456ae:node2:sensor_luminance for DecimalType
2020-03-17 23:20:23.240 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Initialising cmd channel zwave:device:55f456ae:node2:alarm_motion for OnOffType
2020-03-17 23:20:23.241 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Initialising state channel zwave:device:55f456ae:node2:alarm_motion for OnOffType
2020-03-17 23:20:23.242 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Initialising cmd channel zwave:device:55f456ae:node2:battery-level for PercentType
2020-03-17 23:20:23.244 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Initialising state channel zwave:device:55f456ae:node2:battery-level for PercentType
2020-03-17 23:20:23.246 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Polling initialised at 1800 seconds - start in 1744200 milliseconds.
2020-03-17 23:20:23.246 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Device initialisation complete.
2020-03-17 23:20:41.786 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - ZWave discovery: Stop zwave:serial_zstick:55f456ae
2020-03-17 23:20:41.787 [DEBUG] [ve.internal.protocol.ZWaveController] - ZWave inclusion process not running - nothing to do
2020-03-17 23:20:58.572 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Channel zwave:device:55f456ae:node2:sensor_temperature linked - polling started.
2020-03-17 23:21:05.476 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Channel zwave:device:55f456ae:node2:sensor_luminance linked - polling started.
2020-03-17 23:21:14.741 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Channel zwave:device:55f456ae:node2:battery-level linked - polling started.
2020-03-17 23:23:02.942 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'zwave.rules'
2020-03-17 23:23:02.943 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'zwave.rules' is either empty or cannot be parsed correctly!
2020-03-17 23:25:33.565 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'zwave.rules'
2020-03-17 23:26:08.261 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Channel zwave:device:55f456ae:node2:alarm_motion linked - polling started.
2020-03-17 23:26:36.481 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 1C 00 49 84 02 16 04 07 01 5E 98 9F 55 86 73 85 8E 59 72 5A 80 84 30 71 31 70 6C 7A A9
2020-03-17 23:26:36.483 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationUpdate[73], type=Request[0], dest=2, callback=132, payload=84 02 16 04 07 01 5E 98 9F 55 86 73 85 8E 59 72 5A 80 84 30 71 31 70 6C 7A
2020-03-17 23:26:36.483 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationUpdate[73], type=Request[0], dest=2, callback=132, payload=84 02 16 04 07 01 5E 98 9F 55 86 73 85 8E 59 72 5A 80 84 30 71 31 70 6C 7A
2020-03-17 23:26:36.484 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2020-03-17 23:26:36.484 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 0
2020-03-17 23:26:36.484 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: null
2020-03-17 23:26:36.485 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=ApplicationUpdate[73], type=Request[0], dest=2, callback=132, payload=84 02 16 04 07 01 5E 98 9F 55 86 73 85 8E 59 72 5A 80 84 30 71 31 70 6C 7A
2020-03-17 23:26:36.488 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 2: Unsupported command class COMMAND_CLASS_SECURITY_2
2020-03-17 23:26:36.488 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 2: Unsupported command class COMMAND_CLASS_TRANSPORT_SERVICE
2020-03-17 23:26:36.488 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 2: Unsupported command class COMMAND_CLASS_SUPERVISION
2020-03-17 23:26:36.490 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2020-03-17 23:26:36.491 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2020-03-17 23:26:36.741 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: Is awake with 1 messages in the queue
2020-03-17 23:26:36.742 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: Start sleep timer at 5000ms
2020-03-17 23:26:36.742 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Got an event from Z-Wave network: ZWaveNodeStatusEvent
2020-03-17 23:26:36.746 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 2: Node Status event - Node is AWAKE
2020-03-17 23:26:39.242 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: WakeupTimerTask 1 Messages waiting, state STATIC_VALUES
2020-03-17 23:26:41.742 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: WakeupTimerTask 1 Messages waiting, state STATIC_VALUES
2020-03-17 23:26:41.743 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: No more messages, go back to sleep
2020-03-17 23:26:41.743 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 2: Creating new message for application command WAKE_UP_NO_MORE_INFORMATION
2020-03-17 23:26:41.744 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: SECURITY NOT required on COMMAND_CLASS_WAKE_UP
2020-03-17 23:26:41.744 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: Command Class COMMAND_CLASS_WAKE_UP is NOT required to be secured
2020-03-17 23:26:41.744 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: sendTransaction org.openhab.binding.zwave.internal.protocol.transaction.ZWaveCommandClassTransactionPayload@4ca4798e
2020-03-17 23:26:41.745 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Bump transaction 33 priority from Immediate to Immediate
2020-03-17 23:26:41.745 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Adding to device queue
2020-03-17 23:26:41.746 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Added 33 to queue - size 2
2020-03-17 23:26:41.746 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2020-03-17 23:26:41.746 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 02 02 30 01 25 18 E9
2020-03-17 23:26:41.747 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 2: Sending REQUEST Message = 01 09 00 13 02 02 30 01 25 18 E9
2020-03-17 23:26:41.747 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2020-03-17 23:26:41.748 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 32: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 24
2020-03-17 23:26:41.748 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2020-03-17 23:26:41.749 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2020-03-17 23:26:41.749 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2020-03-17 23:26:41.749 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 32: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 24
2020-03-17 23:26:41.750 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2020-03-17 23:26:41.750 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2020-03-17 23:26:41.750 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2020-03-17 23:26:41.755 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2020-03-17 23:26:41.755 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2020-03-17 23:26:41.756 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2020-03-17 23:26:41.756 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 32: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 24
2020-03-17 23:26:41.757 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2020-03-17 23:26:41.757 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 32: [WAIT_RESPONSE] priority=Immediate, requiresResponse=true, callback: 24
2020-03-17 23:26:41.757 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2020-03-17 23:26:41.758 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 32: Advanced to WAIT_REQUEST
2020-03-17 23:26:41.758 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: TID 32: Transaction not completed
2020-03-17 23:26:41.758 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2020-03-17 23:26:41.759 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2020-03-17 23:26:45.989 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 18 01 01 A8 5B
2020-03-17 23:26:45.992 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Request[0], dest=1, callback=24, payload=18 01 01 A8
2020-03-17 23:26:45.993 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Request[0], dest=1, callback=24, payload=18 01 01 A8
2020-03-17 23:26:45.993 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 32: [WAIT_REQUEST] priority=Immediate, requiresResponse=true, callback: 24
2020-03-17 23:26:45.993 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2020-03-17 23:26:45.994 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 32: [WAIT_REQUEST] priority=Immediate, requiresResponse=true, callback: 24
2020-03-17 23:26:45.994 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 32: (Callback 24)
2020-03-17 23:26:45.994 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2020-03-17 23:26:45.994 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 32: callback 24
2020-03-17 23:26:45.995 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Request[0], dest=1, callback=24, payload=18 01 01 A8
2020-03-17 23:26:45.996 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 32: Transaction CANCELLED
2020-03-17 23:26:45.996 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2020-03-17 23:26:45.996 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Transaction failed waiting for REQUEST, assume sleeping device.
2020-03-17 23:26:45.997 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: CANCEL while sending message. Requeueing - 2 attempts left!
2020-03-17 23:26:45.997 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 32: Transaction RESET with 2 retries remaining.
2020-03-17 23:26:45.998 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Adding to device queue
2020-03-17 23:26:45.998 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: Added 32 to queue - size 2
2020-03-17 23:26:45.998 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2020-03-17 23:26:45.999 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 2: TID 32: Transaction not completed
2020-03-17 23:26:45.999 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2020-03-17 23:26:45.999 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2020-03-17 23:30:04.824 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 1C 00 49 84 02 16 04 07 01 5E 98 9F 55 86 73 85 8E 59 72 5A 80 84 30 71 31 70 6C 7A A9
2020-03-17 23:30:04.825 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationUpdate[73], type=Request[0], dest=2, callback=132, payload=84 02 16 04 07 01 5E 98 9F 55 86 73 85 8E 59 72 5A 80 84 30 71 31 70 6C 7A
2020-03-17 23:30:04.826 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationUpdate[73], type=Request[0], dest=2, callback=132, payload=84 02 16 04 07 01 5E 98 9F 55 86 73 85 8E 59 72 5A 80 84 30 71 31 70 6C 7A
2020-03-17 23:30:04.826 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2020-03-17 23:30:04.826 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 0
2020-03-17 23:30:04.827 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: null
2020-03-17 23:30:04.827 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=ApplicationUpdate[73], type=Request[0], dest=2, callback=132, payload=84 02 16 04 07 01 5E 98 9F 55 86 73 85 8E 59 72 5A 80 84 30 71 31 70 6C 7A
2020-03-17 23:30:04.828 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 2: Unsupported command class COMMAND_CLASS_SECURITY_2
2020-03-17 23:30:04.828 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 2: Unsupported command class COMMAND_CLASS_TRANSPORT_SERVICE
2020-03-17 23:30:04.828 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 2: Unsupported command class COMMAND_CLASS_SUPERVISION
2020-03-17 23:30:04.829 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2020-03-17 23:30:04.830 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2020-03-17 23:30:05.080 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: Is awake with 2 messages in the queue
2020-03-17 23:30:05.080 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 2: Start sleep timer at 5000ms
2020-03-17 23:30:05.081 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Got an event from Z-Wave network: ZWaveNodeStatusEvent
2020-03-17 23:30:05.083 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 2: Node Status event - Node is AWAKE
