I’m using a battery-driven Multisensor zooz ZSE40 with the measure of humidy and temperature. The update of this values takes a long time, so I contact the manufacturer.
He wrote:
The sensor will only report according to thresholds set by default or adjusted in advanced settings. If you’d like it to report temperature and humidity more often, we recommend setting the reporting threshold lower:
Parameter: 2, size: 1 byte dec, Value: 5
Parameter: 3, size: 1 byte dec, Value: 5
How can I do that? Can I update it in karaf? In the web-ui I had nothing found.?
Cincerely
Jens
