Hi
I’m new to OH, trying to migrate my zwave setup from Vera.
Installed openhab-transport-serial and latest snapshot of z-wave (2.4.0.201809142025). It successfully detected my Z-Stick Gen5 which was already paired with a Cooper RF9534-NSG dimmer which is almost in the database (but is not approved), with a “small” difference in manufacturerRef: 4449:0001 vs 4449:0002 in the database.
Dimmer shows up in the inbox as an unknown device. At the same time I see this in the log:
18-09-15 16:57:16.888 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 2: Device discovery could not resolve to a thingType! 001A:4449:0001::3.4
Then when I’m trying to change device location I get this
2018-09-15 16:58:22.858 [ERROR] [st.core.internal.thing.ThingResource] - Exception during HTTP PUT request for update config at 'things/zwave:device:512:node2/config'
at org.openhab.binding.zwave.handler.ZWaveThingHandler.handleConfigurationUpdate(ZWaveThingHandler.java:805) [222:org.openhab.binding.zwave:2.4.0.201809142025]
at org.eclipse.smarthome.core.thing.internal.ThingRegistryImpl.updateConfiguration(ThingRegistryImpl.java:92) [108:org.eclipse.smarthome.core.thing:0.10.0.oh230]
at org.eclipse.smarthome.io.rest.core.internal.thing.ThingResource.updateConfiguration(ThingResource.java:425) [118:org.eclipse.smarthome.io.rest.core:0.10.0.oh230]
PaperUI tells me that “This device has not been fully discovered by the binding” and I don’t see any way to control it.
Crudely changing manufacturerRef to 4449:0001 in thing/cooper/rf9534_0_0.xml makes it work, but NPE on setting location is still there.
Should I submit a new database entry?
