[solved] Zwave USB stick not found after updating to OH4
Good morning,
after I upgraded from OH 3.4 to 4.3.2 yesterday - I did this by installing a clean image and then restored from backup - my Zwave stick is no longer found.
I found some posts here e.g. [SOLVED] Z-Wave Serial Controller shows "OFFLINE - BRIDGE_OFFLINE Controller is offline" - #55 by westinpigott that I have to prepare the serial port using openhabian-config, but still the stick is not showing up:
openhabian@openhabian:~ $ dmesg | grep tty
[    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 cgroup_disable=memory snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=720 bcm2708_fb.fbheight=480 bcm2708_fb.fbdepth=16 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3f000000 vc_mem.mem_size=0x3f600000  console=ttyAMA0,115200 console=tty1 root=PARTUUID=1b95f257-02 rootfstype=ext4 fsck.repair=yes rootwait
[    0.000396] printk: console [tty1] enabled
[    2.811684] 3f215040.serial: ttyS0 at MMIO 0x3f215040 (irq = 71, base_baud = 50000000) is a 16550
[    2.812965] serial serial0: tty port ttyS0 registered
[    2.953930] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 99, base_baud = 0) is a PL011 rev2
[    2.957548] printk: console [ttyAMA0] enabled
[    7.611754] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
[    7.634135] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
[    7.722866] systemd[1]: Expecting device dev-ttyAMA0.device - /dev/ttyAMA0...
[    9.449039] systemd[1]: Found device dev-ttyAMA0.device - /dev/ttyAMA0.
Before the update it was /dev/ttyACM0
Am I missing a step?
Seems to be solved after a poweroff / poweron cycle - I was using only reboots before
