I have a Widom switch (WDS2) which is not recognised. I first thought the DB entry is missing. The device manufacturer and the device ID that paperUI shows are not in the DB:
Where can I find the latest .jar (if I understood correctly then I would need to remove the binding installed via PaperUI and install the .jar manually)? Would I lose the configuration or can I just uninstall and reinstall the binding and the configuration remains?
Edit: it looks like PaperUI converts the value to DEC. I assume it is already DEC and should not be converted again though?
hello everybody! after a little pressing but widom in now fully compatible with openhab. be sure to have the latest firmware version. i’m doing the testing right now with the latest 2.5 snapshot of zwave binding
