Hello Stefan
At first. Welcome to the OH Community ![]()
As Udo pointed out already: If you new with OH. Start with OH2, otherwise you have to learn some things twice.
Yes… you have to buy them. Most of the bindings use some API’s of the Bridge/hub/whatever
 so you Need to have These Units.
Don’t worry about Linux skills. Since @ThomDietrich have build “openHABian”, an Linux Installer with openHAB for RPI, you don’t Need to know Linux in deep. What you Need, you will learn by doing. You can find Information about this installer here
I recommend you an seperate machine, because the longer, the more you Need it up ‘n’ running… Please take a look at the recommendations reagrding SD Cards at RPI.
It sounds like you are an perfect candidate for zwave. You’ll find presence sensors, RGBW Controllers, Dimmers, Switches and much more, which will fit your Needs.
Such Projects could get very complicated very fast. I recommend you to start with some Basics, build up your skills and extend your Project step by step.
you’ll find many bindings for your Needs (Samsung, Fritzbox, Geofancing <== your early-warning-system, Kodi)
Actually, I plan my own house renovation, so I can feel with you…
Enjoy!!
Michael
