Hi, currently I’m a bit “lost in the woods” and hope that some of you can point me in the right direction…
what I have / what works:
- approx. 30 zigbee-compatible bulbs (hue, Osram lightify, Innr)
- hue Bridge 2.0
- 2x hue dimmer Switch
- 1x hue tap Switch
- 1x nest protect
- 1x Google Home
what I want:
- floor heating (preferrably from the new Homematic IP range)
- four exterior blinds (German: “Außenjalousien”)
- some window/door sensors
- temperature (difference) sensor, wind-sensor
- control conventional lighning-fixes (without needing to replace everything with hue)
automation purpose:
- move shaders/shader angle according to temperature, time and wind
- Status display (near the main door) that is “green” when all Windows/doors are closed
for shader control, my vendor recommended EnOcean (bi-directional) actors and switches. He sells modified Homematic CCU2 devices with EnOcean module and antenna… but that means yet another eco-system…
I would be thankful to hear some of your thoughts on how to carry on from here… If I buy the CCU2, I could control everything from there… can I?!
So, where does OpenHAB come into play?! I know, that is an heretical question in an OH community
thanks in advance.
