Something up with remote repository?
Just cleared my cache and started openhab and getting stuck downloading any bindings etc.
My end or openhab end? not had any issues previously (and i clear the cache alot :slight_smile: )
2021-04-12 16:24:36.650 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2021-04-12 16:24:42.810 [thome.event.ExtensionEvent] - Extension 'package-standard' has been installed.
2021-04-12 16:24:45.042 [thome.event.ExtensionEvent] - Extension 'package-standard' has been installed.
2021-04-12 16:24:48.406 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-ui-homebuilder, openhab-persistence-rrd4j, openhab-ui-basic, openhab-misc-homekit, openhab-misc-openhabcloud, openhab-ui-habmin, openhab-ui-habpanel, openhab-ui-paper, openhab-binding-zigbee': Error:
Error downloading mvn:org.openhab.persistence/org.openhab.persistence.rrd4j/[1.14.0,1.15)
2021-04-12 16:24:59.403 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-ui-homebuilder, openhab-persistence-rrd4j, openhab-ui-basic, openhab-misc-homekit, openhab-misc-openhabcloud, openhab-ui-habmin, openhab-ui-habpanel, openhab-ui-paper, openhab-binding-zigbee': Error:
2021-04-12 16:25:59.418 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-ui-homebuilder, openhab-persistence-rrd4j, openhab-ui-basic, openhab-misc-homekit, openhab-misc-openhabcloud, openhab-ui-habmin, openhab-ui-habpanel, openhab-ui-paper, openhab-binding-zigbee': Error:
2021-04-12 16:26:59.309 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-ui-homebuilder, openhab-persistence-rrd4j, openhab-ui-basic, openhab-misc-homekit, openhab-misc-openhabcloud, openhab-ui-habmin, openhab-ui-habpanel, openhab-ui-paper, openhab-binding-zigbee': Error:
2021-04-12 16:27:59.416 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-ui-homebuilder, openhab-persistence-rrd4j, openhab-ui-basic, openhab-misc-homekit, openhab-misc-openhabcloud, openhab-ui-habmin, openhab-ui-habpanel, openhab-ui-paper, openhab-binding-zigbee': Error:
2021-04-12 16:28:59.369 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-ui-homebuilder, openhab-persistence-rrd4j, openhab-ui-basic, openhab-misc-homekit, openhab-misc-openhabcloud, openhab-ui-habmin, openhab-ui-habpanel, openhab-ui-paper, openhab-binding-zigbee': Error:
2021-04-12 16:29:59.438 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-ui-homebuilder, openhab-persistence-rrd4j, openhab-ui-basic, openhab-misc-homekit, openhab-misc-openhabcloud, openhab-ui-habmin, openhab-ui-habpanel, openhab-ui-paper, openhab-binding-zigbee': Error:
2021-04-12 16:30:59.365 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-ui-homebuilder, openhab-persistence-rrd4j, openhab-ui-basic, openhab-misc-homekit, openhab-misc-openhabcloud, openhab-ui-habmin, openhab-ui-habpanel, openhab-ui-paper, openhab-binding-zigbee': Error:
Ich think this is related:
https://community.openhab.org/t/bintray-down-is-there-a-change-to-another-repository/120705**strong text**
Thanks @christoph_wempe for confirming.
This proves a HUGE issue..
No dashboard..
No ui’s..
cannot install anything
No fix considering its shutdown as of 1st May?
System down :frowning:
you know where i can get kar file from, had a quick search but cant find?
No.
I just read the other topic and connected the dots to your issue.
It’ll start working again after 2PM Pacific Daylight Time, so a few hours.
Yeah cant wait 2 hours unfortunately.
kar files for 2.5.x if anyone needs (just change search for 3.x) download is top right:
https://search.maven.org/artifact/org.openhab.distro/openhab-addons/2.5.12/kar
Move to kar files, there’s Linux packages that install these.
It’s not very clever to have a home automation system that can work fully autonomously require a download on every start, isn’t it.
So why is the option even available? If that’s the stance then ‘access remote repository’ shouldn’t even be an option… The same as any software having ‘auto update’. Turn it off, lose updates.
Yes the updates to 2.5 are few and far between now but it’s not a viable solution for everyone to upgrade without 3.x packages for the likes of qnap/syno on arm, but things like Zwave database updates still get rolled AFAIK. I’ve had the option enabled since I started a few years ago as many probably have.
I don’t know but there a scenarios where it makes sense I guess ? Such as for a trial or development situation or when you lack disk space.
