I run OH 2.3 on a RPi 3. Sometimes I got the error ‘internal server error: 500’.
I cannot see any pattern when the error occurs. In OH 2.2, the error occurred after 2 - 3 weeks. Now, the interval is smaller: the error occurs approximately daily. I think the rules work, nevertheless, but no controlling with the app or in the browser is possible.
In the openhab.log and the event.log, I can’t see any obvious faults, they just stop suddenly, when the error is generated, but I’m not sure if there is an other log file I have to have a look.
The 500 error indicates a permission issue or possibly an issue with some items with a wrong transformation. Check your items and verify the correct format e.g. [%s] for strings and [%d] for number items.
For an apt-get install you can check the permissions using ls -al /etc/openhab2 and for userdata it’s ls -al /var/lib/openhab2.
I installed install by using openhabian. The actual version then was 2.2, so I upgraded to 2.3 a few weeks ago in the openhab-config. Further, I cleaned the cache. I will check the items, but is it possible that this is the problem ? Does this solution correspond to the issue that the error occurs after a while and not permanent ?
Nevertheless, I check it to rule that out.
If using the openhabian image then you shouldn’t have permission issues but you can always use the openhabian-config tool to fix permissions or make sure their fixed.
I recommend upgrading to 2.4, this is now the latest stable version, as 2.3 is considered fairly old at this point.
That is always a good idea. Also after cleaning the cache you should reboot rather than just starting OH back up. You did stop the OH service before cleaning cache? The correct commands are.
sudo systemctl stop openhab2
sudo openhab-cli clean-cache
sudo reboot
or if prefer to not reboot (future reference) sudo systemctl start openhab2
oh, I did not hear that 2.4 is already released ! the cache should be cleaned well, I did it with a tutorial by @rlkoshak Strange: I had to install all binding again, this took a while…
You’re right, there were some mistakes in my items. What is the correct [%…] for Dimmer, Number:Time, DateTime and Contact ?
2019-01-08 20:45:41.245 [WARN ] [me.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.eclipse.smarthome.io.monitor.internal.EventLogger@b47967' takes more than 5000ms.
2019-01-08 20:45:30.181 [WARN ] [l.handler.ICloudAccountBridgeHandler] - Unable to refresh device data
java.io.IOException: java.util.concurrent.TimeoutException: Total timeout 10000 ms elapsed
at org.eclipse.smarthome.io.net.http.HttpUtil.executeUrlAndGetReponse(HttpUtil.java:259) ~[?:?]
at org.eclipse.smarthome.io.net.http.HttpUtil.executeUrl(HttpUtil.java:156) ~[?:?]
at org.eclipse.smarthome.io.net.http.HttpUtil.executeUrl(HttpUtil.java:131) ~[?:?]
at org.eclipse.smarthome.io.net.http.HttpRequestBuilder.getContentAsString(HttpRequestBuilder.java:135) ~[?:?]
at org.openhab.binding.icloud.internal.ICloudConnection.callApi(ICloudConnection.java:84) ~[?:?]
at org.openhab.binding.icloud.internal.ICloudConnection.requestDeviceStatusJSON(ICloudConnection.java:65) ~[?:?]
at org.openhab.binding.icloud.internal.handler.ICloudAccountBridgeHandler.lambda$0(ICloudAccountBridgeHandler.java:84) ~[?:?]
at org.eclipse.smarthome.core.cache.ExpiringCache.refreshValue(ExpiringCache.java:97) ~[?:?]
at org.eclipse.smarthome.core.cache.ExpiringCache.getValue(ExpiringCache.java:68) ~[?:?]
at org.openhab.binding.icloud.internal.handler.ICloudAccountBridgeHandler.refreshData(ICloudAccountBridgeHandler.java:141) ~[?:?]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) [?:?]
Caused by: java.util.concurrent.TimeoutException: Total timeout 10000 ms elapsed
at org.eclipse.jetty.client.TimeoutCompleteListener.onTimeoutExpired(TimeoutCompleteListener.java:52) ~[?:?]
at org.eclipse.jetty.io.CyclicTimeout$Wakeup.run(CyclicTimeout.java:271) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) ~[?:?]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) ~[?:?]
... 3 more
2019-01-08 20:47:16.104 [ERROR] [ntime.internal.engine.ExecuteRuleJob] - Error during the execution of rule 'Leistung Lowboard': Could not cast NULL to org.eclipse.smarthome.core.library.types.DecimalType; line 79, column 50, length 26
2019-01-08 20:48:07.742 [ERROR] [ntime.internal.engine.ExecuteRuleJob] - Error during the execution of rule 'Leistung Lowboard': Could not cast NULL to org.eclipse.smarthome.core.library.types.DecimalType; line 79, column 50, length 26
2019-01-08 20:49:51.781 [WARN ] [al.connection.YahooWeatherConnection] - Communication error occurred while getting Yahoo weather information: java.util.concurrent.ExecutionException: java.net.UnknownHostException: query.yahooapis.com: No address associated with hostname
2019-01-08 20:51:06.317 [WARN ] [l.handler.ICloudAccountBridgeHandler] - Unable to refresh device data
... 3 more
2019-01-08 20:55:11.957 [WARN ] [al.connection.YahooWeatherConnection] - Communication error occurred while getting Yahoo weather information: java.util.concurrent.ExecutionException: java.net.UnknownHostException: query.yahooapis.com: No address associated with hostname
2019-01-08 20:56:12.032 [WARN ] [me.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.openhab.core.events.internal.EventBridge@fbab0f' takes more than 5000ms.
2019-01-08 20:56:23.429 [INFO ] [control.internal.WebSocketConnection] - Web Socket close 1006. Reason: Disconnected
2019-01-08 20:56:46.226 [WARN ] [l.handler.ICloudAccountBridgeHandler] - Unable to refresh device data
... 3 more
2019-01-08 20:58:09.484 [INFO ] [control.internal.WebSocketConnection] - Web Socket close 4503. Reason: Connection timed out connecting
2019-01-08 20:57:55.209 [WARN ] [mazonechocontrol.internal.Connection] - Request to url 'https://alexa.amazon.de/api/devices-v2/device?cached=false' fails with unkown error
java.net.SocketException: Broken pipe (Write failed)
at java.net.SocketOutputStream.socketWrite0(Native Method) ~[?:?]
at java.net.SocketOutputStream.socketWrite(SocketOutputStream.java:111) ~[?:?]
at java.net.SocketOutputStream.write(SocketOutputStream.java:155) ~[?:?]
at sun.security.ssl.OutputRecord.writeBuffer(OutputRecord.java:431) ~[?:?]
at sun.security.ssl.OutputRecord.write(OutputRecord.java:417) ~[?:?]
at sun.security.ssl.SSLSocketImpl.writeRecordInternal(SSLSocketImpl.java:886) ~[?:?]
at sun.security.ssl.SSLSocketImpl.writeRecord(SSLSocketImpl.java:857) ~[?:?]
at sun.security.ssl.SSLSocketImpl.writeRecord(SSLSocketImpl.java:727) ~[?:?]
at sun.security.ssl.Handshaker.sendChangeCipherSpec(Handshaker.java:1124) ~[?:?]
at sun.security.ssl.ClientHandshaker.sendChangeCipherAndFinish(ClientHandshaker.java:1226) ~[?:?]
at sun.security.ssl.ClientHandshaker.serverHelloDone(ClientHandshaker.java:1138) ~[?:?]
at sun.security.ssl.ClientHandshaker.processMessage(ClientHandshaker.java:358) ~[?:?]
at sun.security.ssl.Handshaker.processLoop(Handshaker.java:1026) ~[?:?]
at sun.security.ssl.Handshaker.process_record(Handshaker.java:961) ~[?:?]
at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:1072) ~[?:?]
at sun.security.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1385) ~[?:?]
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1413) ~[?:?]
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1397) ~[?:?]
at sun.net.www.protocol.https.HttpsClient.afterConnect(HttpsClient.java:559) ~[?:?]
at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(AbstractDelegateHttpsURLConnection.java:185) ~[?:?]
at sun.net.www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1564) ~[?:?]
at sun.net.www.protocol.http.HttpURLConnection.access$200(HttpURLConnection.java:91) ~[?:?]
at sun.net.www.protocol.http.HttpURLConnection$9.run(HttpURLConnection.java:1484) ~[?:?]
at sun.net.www.protocol.http.HttpURLConnection$9.run(HttpURLConnection.java:1482) ~[?:?]
at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
at java.security.AccessController.doPrivilegedWithCombiner(AccessController.java:782) ~[?:?]
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1481) ~[?:?]
at java.net.HttpURLConnection.getResponseCode(HttpURLConnection.java:480) ~[?:?]
at sun.net.www.protocol.https.HttpsURLConnectionImpl.getResponseCode(HttpsURLConnectionImpl.java:347) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.Connection.makeRequest(Connection.java:469) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.Connection.makeRequestAndReturnString(Connection.java:388) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.Connection.makeRequestAndReturnString(Connection.java:383) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.Connection.getDeviceListJson(Connection.java:780) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.Connection.getDeviceList(Connection.java:770) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.handler.AccountHandler.updateDeviceList(AccountHandler.java:495) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.handler.AccountHandler.refreshData(AccountHandler.java:390) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.handler.AccountHandler.checkData(AccountHandler.java:360) ~[?:?]
2019-01-08 20:57:40.543 [WARN ] [me.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.eclipse.smarthome.model.rule.runtime.internal.engine.RuleEngineImpl@34790f' takes more than 5000ms.
2019-01-08 20:58:31.682 [INFO ] [control.internal.WebSocketConnection] - Web Socket error {}
org.eclipse.jetty.io.EofException: null
at org.eclipse.jetty.io.ChannelEndPoint.flush(ChannelEndPoint.java:286) ~[76:org.eclipse.jetty.io:9.4.11.v20180605]
at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.flush(SslConnection.java:1044) ~[76:org.eclipse.jetty.io:9.4.11.v20180605]
at org.eclipse.jetty.io.WriteFlusher.flush(WriteFlusher.java:429) [76:org.eclipse.jetty.io:9.4.11.v20180605]
at org.eclipse.jetty.io.WriteFlusher.write(WriteFlusher.java:323) [76:org.eclipse.jetty.io:9.4.11.v20180605]
at org.eclipse.jetty.io.AbstractEndPoint.write(AbstractEndPoint.java:380) [76:org.eclipse.jetty.io:9.4.11.v20180605]
at org.eclipse.jetty.websocket.common.io.FrameFlusher.flush(FrameFlusher.java:218) [93:org.eclipse.jetty.websocket.common:9.4.11.v20180605]
at org.eclipse.jetty.websocket.common.io.FrameFlusher.process(FrameFlusher.java:157) [93:org.eclipse.jetty.websocket.common:9.4.11.v20180605]
at org.eclipse.jetty.util.IteratingCallback.processing(IteratingCallback.java:241) [88:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.IteratingCallback.iterate(IteratingCallback.java:224) [88:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.websocket.common.io.FrameFlusher.enqueue(FrameFlusher.java:90) [93:org.eclipse.jetty.websocket.common:9.4.11.v20180605]
at org.eclipse.jetty.websocket.common.io.AbstractWebSocketConnection.outgoingFrame(AbstractWebSocketConnection.java:495) [93:org.eclipse.jetty.websocket.common:9.4.11.v20180605]
at org.eclipse.jetty.websocket.client.io.WebSocketClientConnection.outgoingFrame(WebSocketClientConnection.java:72) [92:org.eclipse.jetty.websocket.client:9.4.11.v20180605]
at org.eclipse.jetty.websocket.common.WebSocketSession.close(WebSocketSession.java:223) [93:org.eclipse.jetty.websocket.common:9.4.11.v20180605]
at org.eclipse.jetty.websocket.common.WebSocketSession.close(WebSocketSession.java:202) [93:org.eclipse.jetty.websocket.common:9.4.11.v20180605]
at org.eclipse.jetty.websocket.common.io.AbstractWebSocketConnection.onConnectionStateChange(AbstractWebSocketConnection.java:369) [93:org.eclipse.jetty.websocket.common:9.4.11.v20180605]
at org.eclipse.jetty.websocket.common.io.IOState.notifyStateListeners(IOState.java:184) [93:org.eclipse.jetty.websocket.common:9.4.11.v20180605]
at org.eclipse.jetty.websocket.common.io.IOState.onCloseRemote(IOState.java:373) [93:org.eclipse.jetty.websocket.common:9.4.11.v20180605]
at org.eclipse.jetty.websocket.common.events.AbstractEventDriver.incomingFrame(AbstractEventDriver.java:121) [93:org.eclipse.jetty.websocket.common:9.4.11.v20180605]
at org.eclipse.jetty.websocket.common.WebSocketSession.incomingFrame(WebSocketSession.java:476) [93:org.eclipse.jetty.websocket.common:9.4.11.v20180605]
at org.eclipse.jetty.websocket.common.extensions.ExtensionStack.incomingFrame(ExtensionStack.java:220) [93:org.eclipse.jetty.websocket.common:9.4.11.v20180605]
at org.eclipse.jetty.websocket.common.Parser.notifyFrame(Parser.java:220) [93:org.eclipse.jetty.websocket.common:9.4.11.v20180605]
at org.eclipse.jetty.websocket.common.Parser.parse(Parser.java:245) [93:org.eclipse.jetty.websocket.common:9.4.11.v20180605]
at org.eclipse.jetty.websocket.common.io.AbstractWebSocketConnection.readParse(AbstractWebSocketConnection.java:560) [93:org.eclipse.jetty.websocket.common:9.4.11.v20180605]
at org.eclipse.jetty.websocket.common.io.AbstractWebSocketConnection.onFillable(AbstractWebSocketConnection.java:391) [93:org.eclipse.jetty.websocket.common:9.4.11.v20180605]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:281) [76:org.eclipse.jetty.io:9.4.11.v20180605]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:102) [76:org.eclipse.jetty.io:9.4.11.v20180605]
at org.eclipse.jetty.io.ssl.SslConnection.onFillable(SslConnection.java:291) [76:org.eclipse.jetty.io:9.4.11.v20180605]
at org.eclipse.jetty.io.ssl.SslConnection$3.succeeded(SslConnection.java:151) [76:org.eclipse.jetty.io:9.4.11.v20180605]
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:118) [76:org.eclipse.jetty.io:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:333) [88:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:310) [88:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:168) [88:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:126) [88:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:366) [88:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:762) [88:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:680) [88:org.eclipse.jetty.util:9.4.11.v20180605]
Caused by: java.io.IOException: Broken pipe
at sun.nio.ch.FileDispatcherImpl.write0(Native Method) ~[?:?]
at sun.nio.ch.SocketDispatcher.write(SocketDispatcher.java:47) ~[?:?]
at sun.nio.ch.IOUtil.writeFromNativeBuffer(IOUtil.java:93) ~[?:?]
at sun.nio.ch.IOUtil.write(IOUtil.java:51) ~[?:?]
at sun.nio.ch.SocketChannelImpl.write(SocketChannelImpl.java:471) ~[?:?]
at org.eclipse.jetty.io.ChannelEndPoint.flush(ChannelEndPoint.java:264) ~[?:?]
... 37 more
2019-01-08 20:59:35.801 [WARN ] [me.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.eclipse.smarthome.io.monitor.internal.EventLogger@b47967' takes more than 5000ms.
2019-01-08 21:00:18.022 [WARN ] [me.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.eclipse.smarthome.io.monitor.internal.EventLogger@b47967' takes more than 5000ms.
2019-01-08 21:00:42.431 [WARN ] [me.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.eclipse.smarthome.io.monitor.internal.EventLogger@b47967' takes more than 5000ms.
2019-01-08 21:01:17.907 [WARN ] [al.connection.YahooWeatherConnection] - Communication error occurred while getting Yahoo weather information: java.util.concurrent.TimeoutException: Total timeout 10000 ms elapsed
2019-01-08 21:01:17.911 [ERROR] [io.openhabcloud.internal.CloudClient] - Socket.IO error: {}
io.socket.engineio.client.EngineIOException: websocket error
at io.socket.engineio.client.Transport.onError(Transport.java:71) [217:org.openhab.io.openhabcloud:2.4.0]
at io.socket.engineio.client.transports.WebSocket.access$500(WebSocket.java:28) [217:org.openhab.io.openhabcloud:2.4.0]
at io.socket.engineio.client.transports.WebSocket$2$5.run(WebSocket.java:150) [217:org.openhab.io.openhabcloud:2.4.0]
at io.socket.thread.EventThread$2.run(EventThread.java:80) [217:org.openhab.io.openhabcloud:2.4.0]
Caused by: java.io.EOFException
at okio.RealBufferedSource.require(RealBufferedSource.java:59) ~[?:?]
at okio.RealBufferedSource.readByte(RealBufferedSource.java:72) ~[?:?]
at okhttp3.internal.ws.WebSocketReader.readHeader(WebSocketReader.java:115) ~[?:?]
at okhttp3.internal.ws.WebSocketReader.processNextFrame(WebSocketReader.java:104) ~[?:?]
at okhttp3.internal.ws.RealWebSocket.readMessage(RealWebSocket.java:97) ~[?:?]
at okhttp3.ws.WebSocketCall.createWebSocket(WebSocketCall.java:152) ~[?:?]
at okhttp3.ws.WebSocketCall.access$000(WebSocketCall.java:41) ~[?:?]
at okhttp3.ws.WebSocketCall$1.onResponse(WebSocketCall.java:97) ~[?:?]
at okhttp3.RealCall$AsyncCall.execute(RealCall.java:126) ~[?:?]
at okhttp3.internal.NamedRunnable.run(NamedRunnable.java:32) ~[?:?]
... 3 more
Well, there are quite some bindings with errors in your log file. Just a few observations derived from your posted log file:
For starters, Yahoo has stopped its free API service, so you should replace that binding with something else, like WeatherUnderground or another.
Various other bindings, including iCloud, give some kind of time-out. Have you double checked the binding/things configurations. There may be some errors there.
And for the Amazon Alexa binding you may need to authorize it again. See this thread for all the latest on the Alexa binding.
right, this issue I ignored so far, because couldn’t find any solution for that:
.rules:
rule "Leistung Lowboard"
when Time cron "*/5 * * * * ? *"
if(Power_Plug_Socket_B6.state == OFF) Power_Plug_Socket_B6_num.sendCommand(0.6)
else
Power_Plug_Socket_B6_num.sendCommand((40.0/(8*1023)*(
(red_1.state as DecimalType)+
(green_1.state as DecimalType)+
(blue_1.state as DecimalType)+
(white_1.state as DecimalType)+
(red_2.state as DecimalType)+
(green_2.state as DecimalType)+
(blue_2.state as DecimalType)+
(white_2.state as DecimalType))))
The problem is the conversion from stringiest to a number e.g. “red_1.state as DecimalType”.
