When I woke up this morning, I wondered why all my Somfy roller shutters were still closed - they are supposed to open when the sun rises. Digging in…
Yesterday, Somfy released and force-installed a new firmware 1.29 on their Tahoma Switch boxes. This FW breaks developer mode.
2025-01-29 11:08:47.575 [DEBUG] [very.SomfyTahomaItemDiscoveryService] - Starting scanning for things...
2025-01-29 11:08:47.575 [DEBUG] [nal.handler.SomfyTahomaBridgeHandler] - Sending GET to url: https://192.168.100.211:8443/enduser-mobile-web/1/enduserAPI/setup with data:
2025-01-29 11:08:47.637 [TRACE] [nal.handler.SomfyTahomaBridgeHandler] - Response: {"errorCode":"UNSPECIFIED_ERROR","error":"Unknown object."}
2025-01-29 11:08:47.638 [DEBUG] [nal.handler.SomfyTahomaBridgeHandler] - Received unexpected status code: 400
2025-01-29 11:08:47.639 [DEBUG] [nal.handler.SomfyTahomaBridgeHandler] - Local gateway communication error
java.util.concurrent.ExecutionException: Unknown object.
This affects not only OpenHab, but all home automation systems with a Somfy integration.
An issue on Github is already opened: Can't get local API to work · Issue #161 · Somfy-Developer/Somfy-TaHoma-Developer-Mode · GitHub
To make the binding work again, you currently MUST disable developer mode
