LS,
Our IO heating receivers in our pergola are not found as “Things”. All other “Things” like the bioclimaticpergola, dimmerlight, awning are all discovered correctly via the Tahoma Bridge. The Somfy heating receivers are basically just on/ off switches which in combination with in our case Weinor Tempura Quadra Heaters. The heating receivers function correctly in Tahoma.
https://service.somfy.com/downloads/be_v5/handleidingheating_slim_ontvanger_io.pdf
Arno
