Hey Everyone,
Need a bit of a pointer on the Somfy Tahoma binding please.
I have a Connexoon and I’m running OH3 and have been happily using the binding for a while (about a year), until a week or so back when the bridge stopped communicating and just sat in an error state.
Since then I have tried to upgrade OH, so I am now on 3.1.0 and it is now saying
**COMMUNICATION_ERROR**
Error logging in (check your credentials)
and I have the option to change the Cloud Portal but have left it as www.tahomalink.com.
This error makes sense as I cannot log in to www.tahomalink.com and just get a ‘Login Failed’ error there.
Now, I am in the UK, so I believe when purchased the blinds I set up an account with somfy.co.uk.
I have tried resetting the password and whilst that works and changes a password for somfy.com it still doesn’t let me sign in to tahomalink.com.
I can successfully (or at least it seems) log in to somfy-connect.com and it tries to pass me over to tahomalink.com but still fails to log in to that.
I’ve contacted Somfy UK Support who have said there has been no changes on their side (which I am taking with a pinch of salt) and they are not sure why somfy-connect.com would ever redirect me to tahomalink.com as that is the US site.
I can use the mobile app fine though and have tried leaving it disabled for a few days as well, as I have seen some posts about accounts getting locked.
So my questions:
Are there others in the UK which are able to sign in to tahomalink.com and still have the binding working?
Is there something else that I should be doing instead in the config?
Hi, which version of somfy tahoma binding are you using? I’m using 3.0.2.
Not sure about your comments - I do not need to set a url in my tahoma binding. but of course username, password and …the pin (xxxx-xxxx-xxxx). the pin is shown as soon as logged in as part of your device description. i don’t have a “thing” file anymore, it’s all set at the UI.
I think I was on 3.0.1 (or maybe 3.0.2) when it first stopped working, thought maybe an upgrade would resolve it and I am now on 3.1.0.
That version lets you select the portal but based on the Docs etc, I should be leaving that as the default ``www.tahomalink.com```.
Still requires the username and password but I don’t think it needs the pin now.
I expect this is probably something that Somfy have changed on their end and broken it, but I am hoping that others on here would be able to confirm if it is just an issue with me or more general.
Given it has been a few weeks and no one else has posted, my guess would be an issue with my setup or account somewhere but I am not sure where else to check.
I’m pushing Somfy Support a bit more and see if I can get more detail on the TahomaLink login and things too.
Bumping my old topic as I’ve not had any luck with Somfy Support and I’m still unable to get it to connect in OH.
Are there others in the UK which are able to sign in to tahomalink.com or somfy-connect.com and still have the binding working?
Can you think of anything else that I should try?
Without knowing what other people are seeing for the same setup, I am struggling to push Somfy Support, as I don’t have anything to compare with.
If I can’t get this working (which annoyingly only worked for around a year), I basically just invested in a bunch of dumb blinds and the whole point was to hook it into OpenHab and the whole house automation.
I don’t want to have to use the my phone/app or set specific timers up as that defeats the point of these.
I have managed to get this working now, though I think something in the docs might need updating to cover this example but wanted to add the solution for anyone else that comes up with this issue.
The portal that works for me is tahomalink.com, note the lack of www..
I ended up finding this thread and realised that I should probably be using the Connexoon RTS portal option, which still do not work.
I then went through testing older passwords against that endpoint and couldn’t get anything working.
For quick reference I used this format to ensure the special characters were handled properly: curl -X POST --data-urlencode "userId=<my-email-address>" --data-urlencode "userPassword=<my-password>" -H "Content-Type: application/x-www-form-urlencoded; charset=utf-8" https://ha201-1.overkiz.com/enduser-mobile-web/enduserAPI/login
Still no luck with any of those passwords or the other portals lists in the binding.
I then ended up finding this, noticed the lack of the www. on the tahomalink endpoint and tested curl to that, which worked.
Updated the portal URL on the bridge settings and then everything came online and blinds now work from OH!
