I’m wandering if someone managed to control an FTS system with two separate motors (not wired Somfy FTS with special FTS controller) with Tahoma Binding. Is it even possible? In FTS system two motors have to work in sync and provide tension for fabric. Would it be enough to just simultaneously set both motors to certain position? I understand that there would not be a perfect sync between 2 motors, but I assume eventually they should stop in positions that would provide tension. Maybe there would also have to be some safety measure, eg check that both motors are moving to prevent unwinding of fabric while second motor is stuck.
