- openHABian 3.4.3 on rPi4 with 4GB
I have a SonOFF Zigbee button withe three ways to press the button: single, double, and long.
However, it seems the binding can only detect the single press.
There is also only one ON|OFF channel available in the thing.
Is this a Zigbee binding issue or something I could fix?
E.g., I saw this post, but can neither make sense of the code, nor would I know if this achieves the desired outcome.
I did a TRACE for all three button presses. The double press resulted in a OnCommand rather then a ToggleCommand like the other presses.
# on
2023-08-19 08:31:56.760 [TRACE] [com.zsmartsystems.zigbee.ZigBeeNode ] - 84BA20FFFEDC2D60: ZigBeeNode.commandReceived(ToggleCommand [On/Off: C0A7/1 -> 0000/1, cluster=0006, TID=01])
2023-08-19 08:31:56.761 [TRACE] [.zsmartsystems.zigbee.ZigBeeEndpoint] - 84BA20FFFEDC2D60: Endpoint 1. ZigBeeEndpoint.commandReceived(ToggleCommand [On/Off: C0A7/1 -> 0000/1, cluster=0006, TID=01])
2023-08-19 08:31:56.761 [TRACE] [.zsmartsystems.zigbee.zcl.ZclCluster] - C0A7/1: ZclCluster.handleCommand(ToggleCommand [On/Off: C0A7/1 -> 0000/1, cluster=0006, TID=01])
2023-08-19 08:31:56.762 [TRACE] [.zsmartsystems.zigbee.zcl.ZclCluster] - C0A7/1: ZclCluster.notifyCommandListener org.openhab.binding.zigbee.internal.converter.ZigBeeConverterSwitchOnoff@1d6996a of ToggleCommand [On/Off: C0A7/1 -> 0000/1, cluster=0006, TID=01]
2023-08-19 08:31:56.774 [TRACE] [.zsmartsystems.zigbee.zcl.ZclCluster] - C0A7/1: ZclCluster.notifyCommandListener LATCH Done - true
2023-08-19 08:31:56.856 [TRACE] [transaction.ZigBeeTransactionManager] - notifyTransactionCommand: DefaultResponse [On/Off: 26A9/1 -> 0000/1, cluster=0006, TID=07, commandIdentifier=1, statusCode=SUCCESS] ZigBeeTransaction [ieeeAddress=84BA20FFFEDC2D60 queueTime=92, state=DISPATCHED, sendCnt=1, command=DefaultResponse [On/Off: 0000/0 -> C0A7/1, cluster=0006, TID=01, commandIdentifier=2, statusCode=SUCCESS]]
# off
2023-08-19 08:31:59.746 [TRACE] [com.zsmartsystems.zigbee.ZigBeeNode ] - 84BA20FFFEDC2D60: ZigBeeNode.commandReceived(ToggleCommand [On/Off: C0A7/1 -> 0000/1, cluster=0006, TID=02])
2023-08-19 08:31:59.747 [TRACE] [.zsmartsystems.zigbee.ZigBeeEndpoint] - 84BA20FFFEDC2D60: Endpoint 1. ZigBeeEndpoint.commandReceived(ToggleCommand [On/Off: C0A7/1 -> 0000/1, cluster=0006, TID=02])
2023-08-19 08:31:59.747 [TRACE] [.zsmartsystems.zigbee.zcl.ZclCluster] - C0A7/1: ZclCluster.handleCommand(ToggleCommand [On/Off: C0A7/1 -> 0000/1, cluster=0006, TID=02])
2023-08-19 08:31:59.748 [TRACE] [.zsmartsystems.zigbee.zcl.ZclCluster] - C0A7/1: ZclCluster.notifyCommandListener org.openhab.binding.zigbee.internal.converter.ZigBeeConverterSwitchOnoff@1d6996a of ToggleCommand [On/Off: C0A7/1 -> 0000/1, cluster=0006, TID=02]
2023-08-19 08:31:59.755 [TRACE] [.zsmartsystems.zigbee.zcl.ZclCluster] - C0A7/1: ZclCluster.notifyCommandListener LATCH Done - true
2023-08-19 08:31:59.812 [TRACE] [transaction.ZigBeeTransactionManager] - notifyTransactionCommand: DefaultResponse [On/Off: 26A9/1 -> 0000/1, cluster=0006, TID=08, commandIdentifier=0, statusCode=SUCCESS] ZigBeeTransaction [ieeeAddress=84BA20FFFEDC2D60 queueTime=63, state=DISPATCHED, sendCnt=1, command=DefaultResponse [On/Off: 0000/0 -> C0A7/1, cluster=0006, TID=02, commandIdentifier=2, statusCode=SUCCESS]]
# long on
2023-08-19 08:32:04.086 [TRACE] [com.zsmartsystems.zigbee.ZigBeeNode ] - 84BA20FFFEDC2D60: ZigBeeNode.commandReceived(ToggleCommand [On/Off: C0A7/1 -> 0000/1, cluster=0006, TID=03])
2023-08-19 08:32:04.087 [TRACE] [.zsmartsystems.zigbee.ZigBeeEndpoint] - 84BA20FFFEDC2D60: Endpoint 1. ZigBeeEndpoint.commandReceived(ToggleCommand [On/Off: C0A7/1 -> 0000/1, cluster=0006, TID=03])
2023-08-19 08:32:04.088 [TRACE] [.zsmartsystems.zigbee.zcl.ZclCluster] - C0A7/1: ZclCluster.handleCommand(ToggleCommand [On/Off: C0A7/1 -> 0000/1, cluster=0006, TID=03])
2023-08-19 08:32:04.089 [TRACE] [.zsmartsystems.zigbee.zcl.ZclCluster] - C0A7/1: ZclCluster.notifyCommandListener org.openhab.binding.zigbee.internal.converter.ZigBeeConverterSwitchOnoff@1d6996a of ToggleCommand [On/Off: C0A7/1 -> 0000/1, cluster=0006, TID=03]
2023-08-19 08:32:04.097 [TRACE] [.zsmartsystems.zigbee.zcl.ZclCluster] - C0A7/1: ZclCluster.notifyCommandListener LATCH Done - true
2023-08-19 08:32:04.155 [TRACE] [transaction.ZigBeeTransactionManager] - notifyTransactionCommand: DefaultResponse [On/Off: 26A9/1 -> 0000/1, cluster=0006, TID=09, commandIdentifier=1, statusCode=SUCCESS] ZigBeeTransaction [ieeeAddress=84BA20FFFEDC2D60 queueTime=64, state=DISPATCHED, sendCnt=1, command=DefaultResponse [On/Off: 0000/0 -> C0A7/1, cluster=0006, TID=03, commandIdentifier=2, statusCode=SUCCESS]]
# off
2023-08-19 08:32:07.575 [TRACE] [com.zsmartsystems.zigbee.ZigBeeNode ] - 84BA20FFFEDC2D60: ZigBeeNode.commandReceived(ToggleCommand [On/Off: C0A7/1 -> 0000/1, cluster=0006, TID=04])
2023-08-19 08:32:07.576 [TRACE] [.zsmartsystems.zigbee.ZigBeeEndpoint] - 84BA20FFFEDC2D60: Endpoint 1. ZigBeeEndpoint.commandReceived(ToggleCommand [On/Off: C0A7/1 -> 0000/1, cluster=0006, TID=04])
2023-08-19 08:32:07.576 [TRACE] [.zsmartsystems.zigbee.zcl.ZclCluster] - C0A7/1: ZclCluster.handleCommand(ToggleCommand [On/Off: C0A7/1 -> 0000/1, cluster=0006, TID=04])
2023-08-19 08:32:07.577 [TRACE] [.zsmartsystems.zigbee.zcl.ZclCluster] - C0A7/1: ZclCluster.notifyCommandListener org.openhab.binding.zigbee.internal.converter.ZigBeeConverterSwitchOnoff@1d6996a of ToggleCommand [On/Off: C0A7/1 -> 0000/1, cluster=0006, TID=04]
2023-08-19 08:32:07.587 [TRACE] [.zsmartsystems.zigbee.zcl.ZclCluster] - C0A7/1: ZclCluster.notifyCommandListener LATCH Done - true
2023-08-19 08:32:07.643 [TRACE] [transaction.ZigBeeTransactionManager] - notifyTransactionCommand: DefaultResponse [On/Off: 26A9/1 -> 0000/1, cluster=0006, TID=0A, commandIdentifier=0, statusCode=SUCCESS] ZigBeeTransaction [ieeeAddress=84BA20FFFEDC2D60 queueTime=65, state=DISPATCHED, sendCnt=1, command=DefaultResponse [On/Off: 0000/0 -> C0A7/1, cluster=0006, TID=04, commandIdentifier=2, statusCode=SUCCESS]]
2023-08-19 08:32:07.696 [TRACE] [transaction.ZigBeeTransactionManager] - notifyTransactionCommand: ReportAttributesCommand [On/Off: 26A9/1 -> 0000/1, cluster=0006, TID=61, reports=[AttributeReport [attributeDataType=BOOLEAN, attributeIdentifier=0, attributeValue=false]]] ZigBeeTransaction [ieeeAddress=84BA20FFFEDC2D60 queueTime=118, state=DISPATCHED, sendCnt=1, command=DefaultResponse [On/Off: 0000/0 -> C0A7/1, cluster=0006, TID=04, commandIdentifier=2, statusCode=SUCCESS]]
# double on
2023-08-19 08:32:10.489 [TRACE] [com.zsmartsystems.zigbee.ZigBeeNode ] - 84BA20FFFEDC2D60: ZigBeeNode.commandReceived(OnCommand [On/Off: C0A7/1 -> 0000/1, cluster=0006, TID=05])
2023-08-19 08:32:10.490 [TRACE] [.zsmartsystems.zigbee.ZigBeeEndpoint] - 84BA20FFFEDC2D60: Endpoint 1. ZigBeeEndpoint.commandReceived(OnCommand [On/Off: C0A7/1 -> 0000/1, cluster=0006, TID=05])
2023-08-19 08:32:10.491 [TRACE] [.zsmartsystems.zigbee.zcl.ZclCluster] - C0A7/1: ZclCluster.handleCommand(OnCommand [On/Off: C0A7/1 -> 0000/1, cluster=0006, TID=05])
2023-08-19 08:32:10.491 [TRACE] [.zsmartsystems.zigbee.zcl.ZclCluster] - C0A7/1: ZclCluster.notifyCommandListener org.openhab.binding.zigbee.internal.converter.ZigBeeConverterSwitchOnoff@1d6996a of OnCommand [On/Off: C0A7/1 -> 0000/1, cluster=0006, TID=05]
2023-08-19 08:32:10.499 [TRACE] [.zsmartsystems.zigbee.zcl.ZclCluster] - C0A7/1: ZclCluster.notifyCommandListener LATCH Done - true
2023-08-19 08:32:10.556 [TRACE] [transaction.ZigBeeTransactionManager] - notifyTransactionCommand: DefaultResponse [On/Off: 26A9/1 -> 0000/1, cluster=0006, TID=0B, commandIdentifier=1, statusCode=SUCCESS] ZigBeeTransaction [ieeeAddress=84BA20FFFEDC2D60 queueTime=64, state=DISPATCHED, sendCnt=1, command=DefaultResponse [On/Off: 0000/0 -> C0A7/1, cluster=0006, TID=05, commandIdentifier=1, statusCode=SUCCESS]]
# off
2023-08-19 08:32:13.118 [TRACE] [com.zsmartsystems.zigbee.ZigBeeNode ] - 84BA20FFFEDC2D60: ZigBeeNode.commandReceived(ToggleCommand [On/Off: C0A7/1 -> 0000/1, cluster=0006, TID=06])
2023-08-19 08:32:13.119 [TRACE] [.zsmartsystems.zigbee.ZigBeeEndpoint] - 84BA20FFFEDC2D60: Endpoint 1. ZigBeeEndpoint.commandReceived(ToggleCommand [On/Off: C0A7/1 -> 0000/1, cluster=0006, TID=06])
2023-08-19 08:32:13.119 [TRACE] [.zsmartsystems.zigbee.zcl.ZclCluster] - C0A7/1: ZclCluster.handleCommand(ToggleCommand [On/Off: C0A7/1 -> 0000/1, cluster=0006, TID=06])
2023-08-19 08:32:13.120 [TRACE] [.zsmartsystems.zigbee.zcl.ZclCluster] - C0A7/1: ZclCluster.notifyCommandListener org.openhab.binding.zigbee.internal.converter.ZigBeeConverterSwitchOnoff@1d6996a of ToggleCommand [On/Off: C0A7/1 -> 0000/1, cluster=0006, TID=06]
2023-08-19 08:32:13.130 [TRACE] [.zsmartsystems.zigbee.zcl.ZclCluster] - C0A7/1: ZclCluster.notifyCommandListener LATCH Done - true
2023-08-19 08:32:13.189 [TRACE] [transaction.ZigBeeTransactionManager] - notifyTransactionCommand: DefaultResponse [On/Off: 26A9/1 -> 0000/1, cluster=0006, TID=0C, commandIdentifier=0, statusCode=SUCCESS] ZigBeeTransaction [ieeeAddress=84BA20FFFEDC2D60 queueTime=68, state=DISPATCHED, sendCnt=1, command=DefaultResponse [On/Off: 0000/0 -> C0A7/1, cluster=0006, TID=06, commandIdentifier=2, statusCode=SUCCESS]]
2023-08-19 08:32:13.237 [TRACE] [transaction.ZigBeeTransactionManager] - notifyTransactionCommand: ReportAttributesCommand [Electrical Measurement: 4E37/1 -> 0000/1, cluster=0B04, TID=E4, reports=[AttributeReport [attributeDataType=UNSIGNED_16_BIT_INTEGER, attributeIdentifier=1288, attributeValue=3936]]] ZigBeeTransaction [ieeeAddress=84BA20FFFEDC2D60 queueTime=115, state=DISPATCHED, sendCnt=1, command=DefaultResponse [On/Off: 0000/0 -> C0A7/1, cluster=0006, TID=06, commandIdentifier=2, statusCode=SUCCESS]]
I reckon if the binding does not do the translation of the button commands, I won’t see them in the log either ![]()
Any hints appreciated.
