- Platform information:
Hardware: ODoid
OS: Ubuntu 16.04.7 LTS
Java Runtime Environment: OpenJDK Runtime Environment (build 1.8.0_275-8u275-b01-0ubuntu1~16.04-b01)
openHAB version: 2.5.10-1
- Issue of the topic: Openhab not switching Sonoff lights on/off
I’ve got 3 sonoff lights setup which I last used last Christmas. After Christmas I renamed the rules/items to .old and haven’t used them since. I’ve now configured them again and also updated to version 2.5.10-1. I think previously I was on 2.4
I’ve got a rule where when the XmasGarage light is turned on, it then triggers and turns on XmasKitchen and XmasLounge. All of this was working a year ago.
The problem now is I can see OH2 trying to turn on the lights but none of them switch on.
If I browse to sonoff-garage, sonoff-kitchen, sonoff-lounge I can manually switch the lights on so the devices are on the network and working (Can also ping them from OH2)
sonoff.items
Switch XmasGarage "Christmas Lights" <light> (LR,gLight) ["Lighting"]
{ mqtt=">[mosquitto:cmnd/sonoff-garage.home/POWER:command:*:default],
<[mosquitto:stat/sonoff-garage.home/POWER:state:default]" }
Switch XmasLounge "Lounge Xmas" <light> (LR,gLight) ["Lighting"]
{ mqtt=">[mosquitto:cmnd/sonoff-lounge.home/POWER:command:*:default],
<[mosquitto:stat/sonoff-lounge.home/POWER:state:default]" }
Switch XmasKitchen "Kitchen Xmas" <light> (LR,gLight) ["Lighting"]
{ mqtt=">[mosquitto:cmnd/sonoff-kitchen.home/POWER:command:*:default],
<[mosquitto:stat/sonoff-kitchen.home/POWER:state:default]" }
services/mqtt.cfg
mosquitto.url=tcp://localhost:1883
mosquitto.clientId=openhab
mosquitto.retain=true
mosquitto.async=false
sonoff.rules
rule "Turn on garage xmas lights"
Item XmasGarage changed from OFF to ON
sendCommand(XmasLounge, ON)
sendCommand(XmasKitchen, ON)
rule "Turn off garage xmas lights"
Item XmasGarage changed from ON to OFF
sendCommand(XmasLounge, OFF)
sendCommand(XmasKitchen, OFF)
Logs:
2020-12-05 16:33:36.193 [ome.event.ItemCommandEvent] - Item 'XmasGarage' received command ON
2020-12-05 16:33:36.198 [vent.ItemStateChangedEvent] - XmasGarage changed from OFF to ON
2020-12-05 16:33:36.202 [ome.event.ItemCommandEvent] - Item 'XmasLounge' received command ON
2020-12-05 16:33:36.205 [ome.event.ItemCommandEvent] - Item 'XmasKitchen' received command ON
Any help would be appreciated. I’ve tried removing the tmp and cache directories and rebooted a few times.
Been trying to get this going for hours and out of ideas
I don’t think its a mqtt service issue as I have a few temperature sensors on the network which are using mqtt and sending updated data to OH2
