I have flashed my sonoff devices with Tasmota 5.12.0 and tzhey are working well with my OH2.2 setup.
Looking onto the console of the devices I see all reported times are off an hour in relation to the systemtime (as used by OH). That offset could be not using DST or…
Checking from a PC using mqtt-spy I get messages containing the time (12:00) reported at (13:00 DST).
Is there anything I should have done to correct that is it a known problem or should I just forget about it?
you can request your timezone in the console:
13:56:36 CMD: timezone
13:56:36 MQT: stat/sonoffHeatingIR/RESULT = {"Timezone":2}
or you can set it. I assume, you’re in MESZ? then it’s timezone 2, set it
13:56:33 CMD: timezone 2
13:56:33 MQT: stat/sonoffHeatingIR/RESULT = {"Timezone":2}
that should do it.
Thanks for the response.,
Do I have to change back to Timezone 1 at the end of DST.
depends on how you configured your sonoff in the first place.
but that’s indeed a good question for that I found this one
after reading through this and some more thoughts, I guess timezone 2 would be indeed just the offset, so technically it’s just GMT+2. And so i guess, it won’t change back to standard time.
but if you have defined TIME_DST
and TIME_STD
in user_config.h
correctly, you can use Timezone 99
and should be good to go!
