Does somebody know, if its possible, that Tasmota send me the Status of an GPIO over MQTT every 10 minutes?
In ESP-Easy its possible to define rules, so it is easy
But i prefer Tasmota, becase i think its more stable.
Set GPIO as switch on Tasmota. Look as Switchmode and Switchtopic commands also for configuration of the new-seperate MQTT topic.
Check on Tasmota web console your MQTT topic as you alter the GPIO status. The MQTT topic looks like xxxx/xxx/POWER1 for a Switchmode and Switchtopic configured GPIO.
Now the GPIO has itβs own MQTT topic. You can query this with an OH CRON rule every 10 minutes or grab the GPIO events as most cases do.
