Hi Everyone,
Well, I have been playing with openhab2 for a few weeks now and managed to get it all set up with a rasberry Pi3. Just to get into it I flashed a Sonoff TH16 with Tasmota and set things running with MQTT and Mosquitto.
After a lot of trial and error, forum reading etc etc it worked. TH was reporting both temp and humidity. Fine for a week or so sat on the desk.
Last night it just stopped reporting temp and humidity. Switch and relay work fine.
I have used MQTT.fx and can see that the POWER, RESULT and STATE data is coming in but now no temp or humidity.
Anyone any ideas? I only have one AM2301 and its setup on GPIO14 which it has been from the start.
My next move is to get some more AM2301’s to rule out the sensor failure. But strange it just stopped.
I was playing around with items and sitemaps but that would not affect MQTT.fx I assume…
Well looks like it’s a broken wire in the cable. Bend the cable and it comes back online. Will have to break out the multimeter and find out where! Thanks for your help anyway, I assumed I had something wrong as the sensor is quite new and unused really.
Update
It was not the sensor, it was the socket on the PCB, I gently pressed down the internal pins on the socket and it now has good connection, works perfect again.
