I’m looking for a TRVZB thing code example. The TRVZB is communication via Zigbee2mqtt.
I can help with that, when I’m home after work I’ll post my config for you.
Thank you Maximo
Here’s one of mine. I hope it helps.
UID: mqtt:topic:mosquitto:222ceba67f
label: Radiator (Bathroom)
thingTypeUID: mqtt:topic
configuration: {}
bridgeUID: mqtt:broker:mosquitto
channels:
- id: occupied_heating_setpoint
channelTypeUID: mqtt:number
label: Setpoint
description: ""
configuration:
commandTopic: zigbee2mqtt/Radiator (Bathroom)/set/occupied_heating_setpoint
min: 4
stateTopic: zigbee2mqtt/Radiator (Bathroom)/occupied_heating_setpoint
max: 35
- id: battery
label: Battery
description: ""
configuration:
stateTopic: zigbee2mqtt/Radiator (Bathroom)/battery
max: 100
min: 0
Thank you Maximo. According to the zigbee2mqtt documentation you should use:
stateTopic: zigbee2mqtt/Radiator (Bathroom)**/get/**occupied_heating_setpoint
But this is wrong, it does not work. Your code works well. Thank you.
Nico
Hi Maximo, I added a few more channels, they all work well:
UID: mqtt:topic:MQTTBroker:TRVBZunten
label: TRV Badezimmer unten
configuration: {}
bridgeUID: mqtt:broker:MQTTBroker
channels:
- id: Mode
channelTypeUID: mqtt:string
label: Betriebsmodus
description: " off, heat, auto"
configuration:
allowedStates: off,heat,auto
commandTopic: zigbee2mqtt/TRVBZunten/set/system_mode
postCommand: true
retained: true
stateTopic: zigbee2mqtt/TRVBZunten/system_mode - id: Offset
label: Korrekturwert
description: " -7 … +7 in steps of 0,2"
configuration:
stateTopic: zigbee2mqtt/TRVBZunten/set/local_temperature_calibration - id: Lock
channelTypeUID: mqtt:switch
label: Verriegelung
description: null
configuration:
commandTopic: zigbee2mqtt/TRVBZunten/set/child_lock
stateTopic: zigbee2mqtt/TRVBZunten/child_lock
off: UNLOCK
on: LOCK - id: OpenWindow
label: FensterOffen
description: null
configuration:
commandTopic: zigbee2mqtt/TRVBZunten/set/open_window
stateTopic: zigbee2mqtt/TRVBZunten/get/open_window
off: OFF
on: ON - id: FrostProtectionTemp
label: Frostschutztemperatur
description: " 4 … 10 in steps 1"
configuration:
commandTopic: zigbee2mqtt/TRVBZunten/set/frost_protection_temperature
min: 4
stateTopic: zigbee2mqtt/TRVBZunten/frost_protection_temperature
max: 10 - id: IsTemperature
label: Isttemperatur
description: null
configuration:
stateTopic: zigbee2mqtt/TRVBZunten/local_temperature - id: Battery
label: Batterie
description: null
configuration:
stateTopic: zigbee2mqtt/TRVBZunten/battery
retained: true - id: SetTemperature
label: Solltemperatur
description: null
configuration:
postCommand: true
retained: true
unit: °C
min: 10
max: 25
commandTopic: zigbee2mqtt/TRVBZunten/set/occupied_heating_setpoint
step: 0.5
stateTopic: zigbee2mqtt/TRVBZunten/occupied_heating_setpoint - id: Schedule-Su
label: Badezimmer unten Tagesplan-So
description: null
configuration:
commandTopic: zigbee2mqtt/TRVBZunten/set/weekly_schedule-sunday
postCommand: true
retained: true
stateTopic: zigbee2mqtt/TRVBZunten/weekly_schedule-sunday - id: Schedule-Mo
label: Badezimmer unten Tagesplan-Mo
description: null
configuration:
commandTopic: zigbee2mqtt/TRVBZunten/set/weekly_schedule-monday
postCommand: true
retained: true
stateTopic: zigbee2mqtt/TRVBZunten/weekly_schedule-monday - id: Schedule-Tu
label: Badezimmer unten Tagesplan-Di
description: null
configuration:
commandTopic: zigbee2mqtt/TRVBZunten/set/weekly_schedule-tuesday
postCommand: true
retained: true
stateTopic: zigbee2mqtt/TRVBZunten/weekly_schedule-tuesday - id: Schedule-We
label: Badezimmer unten Tagesplan-Mi
description: null
configuration:
commandTopic: zigbee2mqtt/TRVBZunten/set/weekly_schedule-wednesday
postCommand: true
retained: true
stateTopic: zigbee2mqtt/TRVBZunten/weekly_schedule-wednesday - id: Schedule-Th
label: Badezimmer unten Tagesplan-Do
description: null
configuration:
commandTopic: zigbee2mqtt/TRVBZunten/set/weekly_schedule-thursday
postCommand: true
retained: true
stateTopic: zigbee2mqtt/TRVBZunten/weekly_schedule-thursday - id: Schedule-Fr
label: Badezimmer unten Tagesplan-Fr
description: null
configuration:
commandTopic: zigbee2mqtt/TRVBZunten/set/weekly_schedule-friday
postCommand: true
retained: true
stateTopic: zigbee2mqtt/TRVBZunten/weekly_schedule-friday - id: Schedule-Sa
label: Badezimmer unten Tagesplan-Sa
description: null
configuration:
commandTopic: zigbee2mqtt/TRVBZunten/set/weekly_schedule-saturday
postCommand: true
retained: true
stateTopic: zigbee2mqtt/TRVBZunten/weekly_schedule-saturday
