After the forced move from Sonos to the new App/Tuneln I’m not able anymore to select a radio station. Is there someone who found a solution the select a radio station
I’m using Sonos favorites, so I added a TuneIn (new) station to the Sonos Fav’s and they are selectable via the sonos binding
Thanks Emiel,
That is what I did. I have the radio stations in the list of “Sonos-favorites” but can’t select them. I tried to do this currenttitle and radio but both are not working
sendCommand(Radio2, "NPO Radio 2") // System started
SonosPlay1KeukenCurrenttitle.postUpdate (Radio2.state.toString)
SonosPlay1KeukenRadio.postUpdate (Radio2.state.toString)
sendCommand(SonosPlay1KeukenControl, PLAY)
Can you share your way. Thanks.
I just send the name of the station to an Item, in Blockly. That piece of the code is:
} else if (items.getItem('knoppen').state == '2002') {
items.getItem('Sonos_Connect_Study_Favorite').sendCommand('Deep Radio');
} else if (items.getItem('knoppen').state == '3002') {
items.getItem('Sonos_Connect_Study_Favorite').sendCommand('Sublime');
Thanks. Can you find the channel of Sonos_Connect_Study_Favorite
sure:
the Item is a regular String item
Thanks. I was expecting this but I made a small mistake.
The solution is to use the favorite channel. With the old system I used the radio channel but is not working anymore
