Having installed the latest Sonos binding though the Paper UI, OpenHAB found my Sonos devices and added them to the inbox. I was able to add and configure the channels. The issue I have is when I view the device from openHAB I can skip, pause, play and change the volume but the current track is never displayed.
I have checked the channels configuration and they are enabled. I have also followed the binding Wiki and set up the example using my settings as below.
If I could have a little guidance on where I should be focusing my efforts that would be great!
Site Map:
sitemap demo label=“Main Menu”
Frame label=“Sonos” {
Default item=Sonos_Controller
Slider item=Sonos_Volume
Switch item=Sonos_Mute
Switch item=Sonos_LED
Text item=Sonos_CurrentTrack
Text item=Sonos_State
Could it be that you are using the wrong Channel Type ID? I see that your item Sonos_CurrentTrack is using the currenttrackuri channel, perhaps you should use currentrack instead ?
I have exactly the same problem. Only removing the speaker (things) and the binding and reconnecting them, isn’t solving the issue. Any ideas?
I have two Sonos One connected, both are found automatically and I can add them as new things. Control of the speakers (player controls, mute, stop, favorites, volume) are working, but only uni-directional. No updates on track names, volume (if change outside of openhab) or uri’s are working. Is the binding broken (due to the last updates of Sonos)?
