Hi, I got a new Sonos Era 100 and installed the Sonos binding.
Unfortunately the device is not discovered by the binding. I have openHAB running in a container with network=host. Both (OH and Sonos) are on the same network and no firewall is blocking the communication between them.
When I run a scan in OH I only get the following output (log level for Sonos binding is set to TRACE):
19:13:29.102[DEBUG] [org.openhab.core.config.discovery.internal.DiscoveryServiceRegistryImpl] - Triggering scan for thing types '[sonos:Amp, sonos:ArcSL, sonos:PLAYBAR, sonos:Roam, sonos:RoamSL, sonos:Move, sonos:OneSL, sonos:PLAY3, sonos:Five, sonos:Arc, sonos:PLAY5, sonos:ArcUltra, sonos:Beam, sonos:Move2, sonos:Era300, sonos:Port, sonos:Era100, sonos:CONNECT, sonos:zoneplayer, sonos:PLAYBASE, sonos:SYMFONISK, sonos:One, sonos:PLAY1, sonos:CONNECTAMP]' on 'UpnpDiscoveryService'...
19:13:34.111[DEBUG] [org.openhab.core.io.rest.core.internal.discovery.DiscoveryResource] - Scan for binding 'sonos' successfully finished.
My system:
openHAB 5.0.3
Release Build
Main UI Commit 4cdd594a
container running with network = host
Sonos Era100
Version: 17.7 (92.0-71170)
Does anybody have an idea what else I could try?
A try with HA container (network = host, some container host) could found the Sonos device.
Best regards,
Patrick
