I have two Sonos speakers one called: kitchen and the other: dining room
I Know I know you need to configure a rule to get them to group then use that group in items and call that group.However after looking at all the form posts on here about bindings I’m still confused and can not get it to work. I have looked at all the results for this google search Here.
Can someone please explain how I group 2 Sonos Play:3’s with example Items,Rules and Sitemaps. In a simple and easier beginner friendly way
Also I would upload my items and sitemap but there is commented code all over the place as I have been testing all those results, However I can upload them if needed. Also for refrence I’m runing Openhabian 2.5.0-1 on a Raspberry Pi 3B +
Surely it would as both speakers are one so play/pause both at the same time and both will be playing the same song maybe not for volume as that can be adjusted individually and as a gorup…
Hi Ben,
I suggest you read up a bit on the Sonos binding in the docs and experiment. Then post your configs when necessary. Also search the forum as all of your questions have been asked before in one way or another.
Hi Maurits,
i have some problem by adding as speaker to a group. Can you post your Things-File for your example? I think “st” ist your room? This doesn’t work for me.
Here is my Things-File an my Rules-File.
thanks for your welcome greetings an your help!
Now it works fine. I’ve tryed the name “Bad”, but it was a copy-error in the Items-File After your confirmation i found the error.
And here is a test for the fences from the events-Log.
2019-12-29 09:40:32.961 [ome.event.ItemCommandEvent] - Item 'Sonos_Kueche_Add' received command Bad
2019-12-29 09:40:32.962 [nt.ItemStatePredictedEvent] - Sonos_Kueche_Add predicted to become Bad
