Currently have a problem where sonos speakers are disconnecting after 30 minutes (openHAB 3.4.1 - Release Build)
Have seen "HELP! My UPnP device isn't working right!" and other short stories and have updated the threading etc and my config now shows:
openhab> log:tail org.jupnp.OSGiUpnpServiceConfiguration
14:44:25.729 [INFO ] [rg.jupnp.OSGiUpnpServiceConfiguration] - OSGiUpnpServiceConfiguration createConfiguration threadPoolSize = -1 false
14:44:25.779 [INFO ] [rg.jupnp.OSGiUpnpServiceConfiguration] - OSGiUpnpServiceConfiguration createConfiguration asyncThreadPoolSize = -1 false
14:44:25.787 [INFO ] [rg.jupnp.OSGiUpnpServiceConfiguration] - OSGiUpnpServiceConfiguration retryAfterSeconds = 5
14:44:25.797 [INFO ] [rg.jupnp.OSGiUpnpServiceConfiguration] - OSGiUpnpServiceConfiguration retryIterations = 5000
14:44:25.805 [INFO ] [rg.jupnp.OSGiUpnpServiceConfiguration] - OSGiUpnpServiceConfiguration timeoutSeconds = 60
In my setup the sonos devices and open hab are in different vlans (with a unifi usg pro 4).
I’ve got igmp proxy, the TTL to 4, firewall rules etc - and its working fine on the sonos mobile controller between subnets, and also in openhab for 30 minutes.
Openhab starts up (its in a docker, but attached to the host network), sonos devices available for 30 minutes - i.e. i dont have to click discover at first boot. And then after almost exactly 30 minutes they change to showing as offline.
46:25.503 [INFO ] [openhab.event.ThingStatusInfoEvent ] - Thing 'sonos:PLAY3:RINCON_5CAAFD592DD401400' updated: OFFLINE (COMMUNICATION_ERROR)
12:46:25.511 [INFO ] [openhab.event.ThingStatusInfoEvent ] - Thing 'sonos:CONNECT:RINCON_949F3EBA334201400' updated: OFFLINE (COMMUNICATION_ERROR)
12:46:25.517 [INFO ] [openhab.event.ThingStatusInfoEvent ] - Thing 'sonos:PLAY3:RINCON_B8E937D6CDB001400' updated: OFFLINE (COMMUNICATION_ERROR)
12:46:25.524 [INFO ] [openhab.event.ThingStatusInfoEvent ] - Thing 'sonos:PLAY5:RINCON_949F3E53E74C01400' updated: OFFLINE (COMMUNICATION_ERROR)
12:46:26.596 [INFO ] [openhab.event.ThingStatusInfoEvent ] - Thing 'sonos:PLAY5:RINCON_949F3E53E74C01400' updated: OFFLINE (COMMUNICATION_ERROR): The UPnP device RINCON_949F3E53E74C01400 is not yet registered.
Then going to add device, click sonos and then scan, and they are all immdiately back online:
12:48:41.899 [INFO ] [os.internal.handler.ZonePlayerHandler] - UPnP device RINCON_949F3EBA334201400 is present (thing sonos:CONNECT:RINCON_949F3EBA334201400)
12:48:41.922 [DEBUG] [os.internal.handler.ZonePlayerHandler] - Polling job
12:48:41.915 [DEBUG] [covery.ZonePlayerDiscoveryParticipant] - Discovered a Sonos 'sonos:PLAY5' thing with UDN 'RINCON_949F3E53E74C01400'
12:48:41.911 [INFO ] [os.internal.handler.ZonePlayerHandler] - UPnP device RINCON_949F3E53E74C01400 is present (thing sonos:PLAY5:RINCON_949F3E53E74C01400)
12:48:41.932 [DEBUG] [os.internal.handler.ZonePlayerHandler] - Polling job
12:48:41.941 [DEBUG] [covery.ZonePlayerDiscoveryParticipant] - Created a DiscoveryResult for device '10.3.1.124 - Sonos Connect' with UDN 'RINCON_949F3EBA334201400'
12:48:41.953 [DEBUG] [covery.ZonePlayerDiscoveryParticipant] - Created a DiscoveryResult for device '10.3.1.17 - Sonos Play:5' with UDN 'RINCON_949F3E53E74C01400'
12:48:41.952 [DEBUG] [os.internal.handler.ZonePlayerHandler] - RINCON_949F3EBA334201400: Subscribing to service DeviceProperties...
12:48:41.986 [DEBUG] [os.internal.handler.ZonePlayerHandler] - RINCON_949F3E53E74C01400: Subscribing to service DeviceProperties...
On the USG router I’ve got logging for any blocked intervlan or to fw packets - and not seeing anything flagged there.
Have also seen Sonos speakers disonnecting - #2 by JustinG but no updates for a solution.
Cheers, Ross
