Running OH2 with different bindings here, one of them is Sonos, installed via PaperUI and also linked via PaperUI to an “empty” item defined in sonos.items.
In my Sonos Favorites I have defined 2 radio stations and one playlist, this playlist does not come from Sonos itself but is a dynamic playlist from Spotify (Relax & Unwind). The radio stations are coming from TuneIn.
sonos.items
String Sonos_Keuken_Favorite "Sonos Keuken Favoriet"
test.sitemap
Frame label="Media" {
Switch item=Sonos_Keuken_Favorite mappings=["MNM"="MNM","VRT Radio 1"="Radio 1","RelaxUnwind"="RelaxUnwind"]
Via PaperUI I have linked the item defined in sonos.items to the channel in PaperUI:
This shows up fine in my BasicUI and I can switch between MNM and Radio 1, no problem there whatsoever. The thing is: I can’t start the RelaxUnwind playlist which comes from Spotify. Just to be clear: I’m not talking about spotify connect. I just want to start a dynamic playlist coming from Spotify
. The playlist is added as a favorite in Sonos. The bizarre thing is that when I create a static Sonos-playlist (not a static playlist in Spotify), containing Spotify tracks it works perfectly. But then the list is not dynamic and stays the same until I change the content of the playlist myself on a certain day.
