Researching, I see lots of talk about the Say command and TTS (especially the loss of Google’s).
Vera/MiOS has a Sonos plugin that allows for use of the Say command and is working with other TTS engines like Mary and Microsoft. I can’t help programming but maybe it can be used as a reference on how to integrate those abilities.
As I am the current maintainer of the Sonos vera plugin and the one who added new TTS engines, I could deal with that for openHAB2, especially the Microsoft TTS engine I am using everyday.
Note that it is not possible in openHAB 1.x to do TTS and play the result on a Sonos device.
You have a “say” action for TTS but it plays the result on the machine running openHAB. Several TTS engines are already available in this case.
I hope it is something that will be enhanced in openHAB 2 so that we can use our Sonos.
On my side, I continue using the Sonos Vera plugin through the MiOS binding. And so I can use Microsoft translator.
Any plans on adding the Microsoft TTS, either standalone or as part of this plugin?
I really liked the plugin on the Vera, not so much every update of the vera breaking the plugin and needing support to fix it.
