Source code of standard widgets
does anyone know where to find the source code of the standard widgets included in the Habpanel.
Reason for asking is the following. I would like to build a custom one for roller schutter and blinds but want it to have the look and feel of the default ones and want to have the same backdrop icon customizations etc.
I figured that if I could start from the code of the standard Label widget for example that that would be help me a lot modifying that rather than trying to build one from scratch. There are a few custom ones shared here but they all have a bit different look and feel.
So being able to upload a label standard widget as custom and starting to adapt that would be great.
There you go:
Hi there,
I´ve seen this topic and don´t want to issue a new one.
Does anyone know how to implement the code files into a custom widget ? I´m using the selection widget for some items. But I´m not satisfied with 2 points:
1.Size and color for “name”
2.Size and color for selection values
I want to modify this in the code, if possible and use it like a custom widget.
Thank you very much.
