Using the Telegram binding it is possible to specify an image which is posted along with the caption. However the image is always scaled up/down to fit the screen size - and sometimes that looks ugly.
Is it possible to specify the picture size which Telegram should use? The Telegram API seems to support this, at least there is a PhotoSize documentation. The openHAB binding can only add a URL or a base64 encoded image, but it’s not possible to specify or influence the actual picture size.
