@Muplex I just did the test. Both the version 1.0.6 and the latest 1.0.7 produce “MBit/s” on my system. Really strange.
@Mitch77 Seems like the variable speedtestCliOutput is empty, that shouldn’t be. You need to debug your rule. First check if the absolute path /usr/local/bin/speedtest-cli is correct. Next check if you can execute the command as user openhab. If so did you install the Exec binding?
You’ll find that it’s often easy to debug on your own.
was working, I found that it took quite a long time til the results came. So I tried to extend the timeout. With 5 minutes timeout it’s working now. FTR: I changed the following line in your rule to:
var String speedtestCliOutput = executeCommandLine("/usr/local/bin/speedtest-cli@@--simple",5*60*1000)
I read the entire thread, but I am still not aware how my speedtest data is stored in influxdb.
In the provided python script (first post from ThomDietrich), db and ip etc is specified in the script.
Probably it is easy, but I can not see the wood for the trees.
The script just updates the corresponding openHAB Items you have created.
The items then get stored in influxdb with the persistence service, you have configured in openHAB.
This started to happen for me let’s say 1-2 month ago. The funny thing is that manually it just works…100%. I see this error message only with time based rule-start. This is the part of my rule:
rule “Speedtest”
Time cron “0 00 01 * * ?” or // Every day 01:00
Item SpeedtestRerun received command ON
then {
Very strange…Any ideas what causes this error? I’m always on latest snapshot.
kris@OpenHAB:~$ speedtest-cli --simple
Cannot retrieve speedtest configuration
ERROR: <urlopen error [Errno -2] Name or service not known>
kris@OpenHAB:~$
This is all working great for me except the chart which is blank. I am using MySQL persistence and can see my ISP data being added in the tables. I’m not sure where I’m going wrong
