I have two rules M and T which uses the same functionality in the background. This is made in the classes MH and TH. They are also rules as they also use the functionality of rules. MH and TH are identical, but need to be different instances.
They are implemented in the same file as the calling rule (M and MH, T and TH). See abstract example below.
As MH and TH are identical I would like to separate them in another file. Usually I would place it in the lib folder and import that rule class, but the documentation states not to do so:
lib: lib # Custom modules, libraries and files can be placed there.
# (!) Attention (!):
# Don't create rule instances in files inside the lib folder! It will lead to strange behaviour.
Example of M and MH:
from typing import Awaitable, Callable
from HABApp import Rule
class MH(Rule):
def __init__(
self,
ItemName1: str,
ItemName2: str,
ExecFunction: Callable[[str, str, str], Awaitable[bool]],
) -> None:
super().__init__()
return
class M(Rule):
def __init__(self) -> None:
super().__init__()
self.MBH: MH = MH("ItemName1", "ItemName2", self.ExecFunction)
return
async def ExecFunction(
self, Par1: str, Par2: str, Par3: str
) -> bool:
return False
I tried some variants to call MH when it is implemented in its own rule file, but always failed. What is the right way to achieve this?
