Hi, might be posting this is the wrong area. But hopefully its ok.
I am looking to be able to add spotify controlls to my hab panel.
I would like to be able to adjust volume and all the basics.
If possible also album art to see what is currently playing.
Is there a addon for this? I couldnt find any but maybe someone can point me in the right direction.
Oh offcorse, im stuck at the part where i need to authenticate. “Click authenticate”. And when i do it just returns Invaliv client. And if i try to run spotify .py i get errors.
Hi, I’m new to the community and it’s been a long time coming to the part where we need to authenticate. But I will help you with some screenshots.
Authenticate your New App for your Spotify User
Go to: http://openhabianpi.local:8080/static/spotify-auth.html
You should see a page called "Spotify Integration" with a status message "Click here to Authenticate"
Click the link and authenticate your app
When done, the page returns and displays "New Auth Code successfully saved to OpenHab!"
Check that the spotify_auth_code is set in OpenHab
omg… i worked it out… i had the brackets around the client id. wich caused issues. Thanks again guys!
But i encountered another issue. When i run spotify.py this appears:
Error getting state from OpenHab: spotify_client_id (HTTP Response 404)
Error getting state from OpenHab: spotify_client_secret (HTTP Response 404)
Error getting state from OpenHab: spotify_access_token (HTTP Response 404)
Error getting state from OpenHab: spotify_refresh_token (HTTP Response 404)
Error getting state from OpenHab: spotify_token_issued (HTTP Response 404)
Error getting state from OpenHab: spotify_token_expiry (HTTP Response 404)
Traceback (most recent call last):
File “/etc/openhab2/scripts/spotify.py”, line 384, in
main()
File “/etc/openhab2/scripts/spotify.py”, line 347, in main
c = spotify()
File “/etc/openhab2/scripts/spotify.py”, line 47, in init
if (time.time() > float(self.token_expiry)):
ValueError: could not convert string to float:
