Hi there,
I’m using a Logitech Media Server Version 7.7.6 and a Squeezebox Classic (modelId “squeezebox3”) with the Squeezebox Binding from openHAB 2.5.11.
The problem is that the player is never reported to be offline even when it has no power. I initially added the player via PaperUI. Later I did the same via textual configuration with the same result:
Bridge squeezebox:squeezeboxserver:myServer [ ipAddress="192.168.5.30", webport=9002, cliport=9090 ]
Thing squeezeboxplayer SqueezeBoxLiving [ mac="00:04:xx:xx:xx:xx" ]
(I used the correct MAC in lower case chars )
The result was the same (player always ONLINE, never OFFLINE).
Is the status of the player taken from the device or via the server? I thought this was caused by the server never reporting the player as OFFLINE - but as soon as I cut the power to the player the server says “no player available” in the web UI.
I even tried to restart the Squeezebox binding when the player was unplugged. But even then the thing was immediately ONLINE.
Any ideas?
